meijin3 Posted March 23, 2013 Report Share Posted March 23, 2013 Hello everyone! I've upgraded my HP dv6 to Windows 8 and I have a recovery partition that is just over 16 gigabytes and mostly full. I'd like to delete this partition (as I did with HP_Tools) and use it for something else (re-size it and use as a Linux swap partition). I created a recovery USB drive but only about 2 gigabytes of my 16 gigabyte USB stick was used to make it. If at some point my C: is completely formatted, does my recovery drive have what I need to re-install Windows? If not, what can I do to make it so? Thanks so much for your help. Quote Link to comment Share on other sites More sharing options...
AlanHo Posted March 23, 2013 Report Share Posted March 23, 2013 I regularly back up both my desktop and notebook computers onto an external hard drive using Acronis. You cannot rely on a recovery partition which is on the same hard drive as your OS and data - sooner or later the hard drive will fail. I would not rely on a USB memory stick - they are too easy to lose. Quote Link to comment Share on other sites More sharing options...
andsome Posted March 23, 2013 Report Share Posted March 23, 2013 Get a decent size plug in drive. Mine is 1TB, but larger ones are available now. I too swear by ACRONIS. I also keep all my downloaded software, and photo's etc on two identical memory sticks. Quote Link to comment Share on other sites More sharing options...
meijin3 Posted March 23, 2013 Author Report Share Posted March 23, 2013 Acronis it is, thanks fellas :) Edit 2: Okay, I'm trying the free trial. Do I just back up SYSTEM and RECOVERY? Can I then delete RECOVERY? Quote Link to comment Share on other sites More sharing options...
