Ashok Reddy Posted November 9, 2013 Report Share Posted November 9, 2013 Dear All, I installed one tape library in rack n that tape library connected to 2K3 through SCSI cable. But i haven't found drivers for this one. I got a question mark symbol in device manager under other devices tab (hp ultrium 3 scsi scsi sequential device). Can any one send me the drivers for this one. I also tried with backup software but the backup software also not found the tape library that means there is no drivers for the tape library. In google i found the drivers but those drivers will not supports 2K3. Please do the needful. Looking forward to your valuable replys. Thanks,Ashok Reddy Quote Link to comment Share on other sites More sharing options...
Gandalph Posted November 9, 2013 Report Share Posted November 9, 2013 Have you tried a Google for the Drivers, or the website that made the components you are trying to connect. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted November 10, 2013 Report Share Posted November 10, 2013 What is the hardware id for that device? You can also try DriverMax to find drivers for "unknown" devices; use the free version that allows two driver downloads per day. Quote Link to comment Share on other sites More sharing options...
Ashok Reddy Posted November 11, 2013 Author Report Share Posted November 11, 2013 What is the hardware it for that device? You can also try DriverMax to find drivers for "unknown" devices; use the free version that allows two driver downloads per day. Thanks for your support. The Operating system is 2003 server. And found the drivers in Google but those drivers wont supports 2K3. I haven't tried with the Drivermax i'll try n get back to u with the status. Thanks, ashok... Quote Link to comment Share on other sites More sharing options...
Ashok Reddy Posted November 11, 2013 Author Report Share Posted November 11, 2013 Have you tried a Google for the Drivers, or the website that made the components you are trying to connect. Thanks for your support. Yes, I tried. but those drivers wont supports 2003 server operating system. Thanks, ashok... Quote Link to comment Share on other sites More sharing options...
