Lamb Chop Posted January 10, 2014 Report Share Posted January 10, 2014 I have seen this for a long time and wondered - how does traffic show when not only shut down the computer but the modem and all shut off at the wall point too. Is this a problem - ie meaning say people can use your computer together with many others with owners unknowing to increase their power like having a Kray or even several linked if enough. should spooky music play when I check my content which usually is only on the day of change over of allowance to see if it did change so get accurate readings. Trying to get screen pic of Du Meter report up here using paint and pictures but seems not as easy as once was. If not here will try on new post. Quote Link to comment Share on other sites More sharing options...
Lamb Chop Posted January 10, 2014 Author Report Share Posted January 10, 2014 Try to uplift screen print for above showing traffic at 11pm last night and 3am today. worked!!! using Apple picture copy and paste via Pale Moon. Well it tried. Re-sized it down to 640x512 smallest on resize but still cant uplift. Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted January 10, 2014 Report Share Posted January 10, 2014 Lamb Chop, you have me baffled, is'nt DU meter a software program that installs on your computer, if so how can you use it with the computer or modem switched off ?. Quote Link to comment Share on other sites More sharing options...
Lamb Chop Posted January 11, 2014 Author Report Share Posted January 11, 2014 That's the whole point I a not using it as power is switched off as I said not only computer itself, but power point on wall as I always switch these off and leave only fridge freezers on. And of course it is a software program that meters my use so can check it and see what is happening all the time when using computer. And stay within allowance as slowed down to 64kps if go over. I wonder why it can show use when no power whatsoever. That is all. Must be an explanation and I cant be only one using DU Meter but guess better try and see if they have a forum. Quote Link to comment Share on other sites More sharing options...
