faruk1 Posted March 9, 2014 Report Share Posted March 9, 2014 I am having problems with the computer at my office. Every time I turn on my computer, it will shut down about one to five minutes after I turn it on, and then restart itself. It does this about 3 or 4 times before it finally starts working and won't randomly shut on and off. My computer is Pentium® Dual-Core [email protected] and 2GB Ram. Quote Link to comment Share on other sites More sharing options...
Belatucadrus Posted March 9, 2014 Report Share Posted March 9, 2014 Very difficult to tell from here, best first suggestions are to do some basic maintenance, run Scandisk, Defrag the disk, run an ativirus scan, and also take an airduster to the PC vents and make sure they're clear. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted March 10, 2014 Report Share Posted March 10, 2014 Check the Event Viewer; it should tell you what went wrong. Most likely under System, at the time it happened. Quote Link to comment Share on other sites More sharing options...
