Hedda5675 Posted May 13, 2014 Report Share Posted May 13, 2014 Actually, I am not really familiar with the computer stuffs and don’t know how to cope with my low disk space problem. In fact, yesterday, when trying to install a photo editing program on my computer, a pop-up was given and told me the system partition had a low disk space problem and needed to be expanded. But, I don’t know how to expand it. Do you know how to do that? What should I do? Detailed steps could be great appreciated! Thanks!! Quote Link to comment Share on other sites More sharing options...
Belatucadrus Posted May 13, 2014 Report Share Posted May 13, 2014 What partitions have you got and how big are they ( size and free space left please )Also which partition were you trying to install the program on.What operating system, ie what version of Windows are you using ? Quote Link to comment Share on other sites More sharing options...
Ray Ferdo Posted July 30, 2014 Report Share Posted July 30, 2014 I am agree with you, I think you need to give more information regarding your problem.. You need to give info regarding your OS, windows version, free space and partition also. Quote Link to comment Share on other sites More sharing options...
Williammbrooks Posted October 18, 2014 Report Share Posted October 18, 2014 Windows Tab:Internet Explorer - Temporary Internet Files, CookiesSystem - Empty Recycle Bin, Temporary Files, Windows Log Files,Applications Tab: FireFox - Cookies, Download History, Internet Cache. Internet - Sun Java.Multimedia - Adobe Flash Player. The 'Analyze' button allows you preview (without actually deleting) what will be deleted and how much hard drive space you will get back. Also available is customization, see Options/Custom to add any other/additional files or folders you want removed. After clicking on the ‘Analyze’ button CCleaner listed almost 1GB of files to be deleted. Quote Link to comment Share on other sites More sharing options...
rabinmistri Posted November 4, 2014 Report Share Posted November 4, 2014 Try to delete or move your data from that drive to another drive. Uninstall programs that are not needed or useless. You can also delete temporary files and cache file for other applications. Quote Link to comment Share on other sites More sharing options...
OttoJ.Federico Posted January 2, 2015 Report Share Posted January 2, 2015 If you have a problem of a low disk space then you need to delete some unwanted files from your C drive and uninstall some less used software that can free up some space. If you have less space in your c drive then you can use some partition manger software to increase its space. Quote Link to comment Share on other sites More sharing options...
