bang1171 Posted June 1, 2014 Report Share Posted June 1, 2014 Hello, I've been using my two monitors for some time now, and they've just seemed to stop working. By this I mean they just show the same image. I've been through the control panel on connecting one, but it only says there is only one screen connect. I've unplugged and replugged both of them individually and at the same time (It still says there is only one screen when I take the other one out) and restarting with these changes and I've been fiddling with the resolution.I've put a picture of what I'm trying to describe, I've taken a picture of both of my monitors on the "Connecting External Display" page in the control panel. Sorry if I'm not describing it very well. Any help would be well appreciated:) Quote Link to comment Share on other sites More sharing options...
bang1171 Posted June 1, 2014 Author Report Share Posted June 1, 2014 Also before this happend I tried to install AMD - Catalyst Control Center which needed a restart - after it restarted my monitors were like this. Quote Link to comment Share on other sites More sharing options...
Boris Posted June 2, 2014 Report Share Posted June 2, 2014 Have you looked at the settings inside Catalyst Control Centre now that you have installed it ? Quote Link to comment Share on other sites More sharing options...
bang1171 Posted June 2, 2014 Author Report Share Posted June 2, 2014 It didn't install properly, so I just uninstalled it Quote Link to comment Share on other sites More sharing options...
Boris Posted June 2, 2014 Report Share Posted June 2, 2014 In that case, try a System Restore back to before you installed Catalyst Control Centre ? Quote Link to comment Share on other sites More sharing options...
