Guest spikeychris Posted October 24, 2003 Report Share Posted October 24, 2003 Lots of the mail I receive concerns networking, and PCA is full of networking issues. It really is quite simple so…. You get cable broadband and you have a couple of machines. You don’t want to buy anything extra but want to share the net.If you’re not bothered about having both machines on the net at the same time (you will have to have the machine that is connected to the net “online” for it to work) then the cheapest way is to install TWO NIC cards in the machine that is connected to the net (host). A network card will cost you less than a tenner and is as simple to fit as a modem. Next, go and buy yourself a crossover cable £4 and shove one end in the host and the other in the second computer (client).Next install Internet connection sharing, it’s a doddle but if you’re having problems use these links http://www.microsoft.com/WindowsXP/pro/usi...working/ics.asphttp://support.microsoft.com/default.aspx?...&NoWebContent=1http://support.microsoft.com/default.aspx?...&NoWebContent=1http://www.infinisource.com/techfiles/ics-...leshooting.htmlhttp://www.dewassoc.com/support/networking/ics_4.htmThis also means you can share files and folders and printers http://www.wown.com/j_helmig/guide.htmhttp://www.dslreports.com/faq/networkinghttp://www.practicallynetworked.com/sharing/troubleshoot/It’s all very simple an at around £14, it hardly breaks the bank…..If you don’t fancy having to have both machines on the net at the same time then go and buy a Router with an inbuilt ethernet switch. Connect that to the cable modem, put one NIC in each machine & connect themto the switch. Doing this means that the machines are independentlyconnected and also the Router acts as a Firewall with NetworkAddress Translation (NAT).Chris Quote Link to comment Share on other sites More sharing options...
bvw Posted October 24, 2003 Report Share Posted October 24, 2003 Excellent post Chris :) Quote Link to comment Share on other sites More sharing options...
rebus Posted October 24, 2003 Report Share Posted October 24, 2003 Thanks ChrisPleasant change to find a diamond amidst the usual dross on here. Quote Link to comment Share on other sites More sharing options...
Guest nellie2 Posted October 24, 2003 Report Share Posted October 24, 2003 Shame to spoil a good post with a comment like that don't you think?? However, everyone is entitled to thier opinion. Quote Link to comment Share on other sites More sharing options...
rebus Posted October 24, 2003 Report Share Posted October 24, 2003 What? Can't bear the truth? Quote Link to comment Share on other sites More sharing options...
Tankus Posted October 24, 2003 Report Share Posted October 24, 2003 HmmmDepends what you want rebus....... Quote Link to comment Share on other sites More sharing options...
Damo Posted October 25, 2003 Report Share Posted October 25, 2003 Bye Bye rebus! Quote Link to comment Share on other sites More sharing options...
Paul Posted October 25, 2003 Report Share Posted October 25, 2003 Thanks ChrisPleasant change to find a diamond amidst the usual dross on here.rebus - If you dont like it here then dont come! simple as that. Quote Link to comment Share on other sites More sharing options...
Guest nellie2 Posted October 25, 2003 Report Share Posted October 25, 2003 What? Can't bear the truth?Like I said, everyone is entitled to their opinion.We have a healthy debates forum for discussion on all sorts of subject. Forum content included if you wishhttp://www.windowsforum.org/support/forum/...php?showforum=8But it doesn't show much respect or consideration to hijack a thread that has been posted in good faith and for the benefit of our community and visitors.We don't have many rules but we do have a couple.... here is the link in case you missed them.http://www.windowsforum.org/service/guidlines.php Quote Link to comment Share on other sites More sharing options...
