AlanHo Posted July 17, 2018 Report Share Posted July 17, 2018 I keep hitting the Caps Lock instead of the Shift key in error - and find out when I have typed several lines of text. I am aware of several software tweaks to disable the key - but you need to do each time you boot up. I am also aware of a regedit mod to disable it permanently but I hate tampering with the registry. My ham-fisted solution is simple - anyone can easily do it - prise the key from the keyboard. Job done. Reply Quote Notify Remove Quote Link to comment Share on other sites More sharing options...
andsome Posted July 17, 2018 Report Share Posted July 17, 2018 It is a pest. If I need to type a capital letter I just press the appropriate key, and don’t need a caps lock key. Quote Link to comment Share on other sites More sharing options...
