moon Posted October 30, 2003 Report Share Posted October 30, 2003 I'm building a graphics machine with a five hundred sov. grant. I haven't got much of a clue yet, other than a SATA 7200 120G hd ( perhaps 2) and USB 2. Any advice ? They give me the dosh after I've spent it. Quote Link to comment Share on other sites More sharing options...
Guest Grim Reaper Posted October 30, 2003 Report Share Posted October 30, 2003 just to clarify here moon old chap.....what are the budget contstraints?one could build a rather good machine with no limits!! Quote Link to comment Share on other sites More sharing options...
moon Posted October 30, 2003 Author Report Share Posted October 30, 2003 500 quid. It would be nice to get a decent monitor in with that- CRT's have crashed and I've seen good 19" for £120 BUT - I think I'll spend extra on the screen later. I've got a couple of useable monitors that will fill in . So, 500 for everything else, inc. vat. A gig of DDR would be nice ? :)EDIT: I've already got the software, Photoshop 7 and W2K Pro. Quote Link to comment Share on other sites More sharing options...
Guest Grim Reaper Posted October 30, 2003 Report Share Posted October 30, 2003 baring in mind that you are trying to build a graphics machine, do you want the latest all singing all dancing graphics card or are you willing to settle for anything less??do you need a new mobo and cpu as well, also, case, modem, sound card, speakers, case........what do you need new and what can you recycle.if you want that all singing graphics card it will use a sizeable chunk of your budget!one other major consideration is which brand of cpu......intel is more expensive than AMD...... Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted October 30, 2003 Report Share Posted October 30, 2003 theres a 19" Dell M922 Monitor here for £115 if you change your mind http://www.autdirect.co.uk/acatalog/index.html Quote Link to comment Share on other sites More sharing options...
monkeyhanger Posted October 30, 2003 Report Share Posted October 30, 2003 Word on the grapevine is that ebuyer will be dropping the price of Athlon 266fsb cpu's this weekend. That will take it up to a max of 2400+Might save a few pennies if you are in the market for one. ;) Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted October 30, 2003 Report Share Posted October 30, 2003 this looks ok ATX M/B with XP3000+ CPU & H/S Fan Just In !!!!!!! Asrock K7S8X MotherboardDDR OnlyDDR 266/333MHz200/266/333 fsb6 PCI1 AGP 4 USB2 PortsSound on BoardLan OnboardAMD XP3000+ ProcessorHeatsink & Fan Price: £165.96 £195.00 Including VAT at 17.5 Quote Link to comment Share on other sites More sharing options...
moon Posted October 30, 2003 Author Report Share Posted October 30, 2003 Yes, complete machine. Onboard sound will be OK, in fact speakers not required for this one. The graphics work is photo-manipulation and web-building, no gaming at all but I want to get as far as I can with Macromedia Flash as a creative tool. Let's say; ATX case and 350 w supply.............................£85Socket A board. 5xUSB 2. Onboard sound.........£702x 512 DDR...................................................£140Min. 2GHz Athlon CPU.....................................£1407200 SATA 120Gig Seagate..............................£80Fans, floppy, extra bits.....................................£80.....not much left for a graphics card already :D :DEDIT : Blimey ! Where'd you lot spring from ? I was toying some specs. with his Lordship. Quote Link to comment Share on other sites More sharing options...
Guest Grim Reaper Posted October 30, 2003 Report Share Posted October 30, 2003 http://www.rlsupplies.co.uk/index.htmsome very good cheap stuff here....someone originally posted it here but i can't remember who it was.....they are really reliable too. Quote Link to comment Share on other sites More sharing options...
moon Posted October 30, 2003 Author Report Share Posted October 30, 2003 Ellas, just in where ? Are some of you guys dealers ? B) Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted October 30, 2003 Report Share Posted October 30, 2003 best of gettin a motherboard bundle some goods ones at the link with the monitor. Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted October 30, 2003 Report Share Posted October 30, 2003 whoops sorry look at the mobo bundles http://www.autdirect.co.uk/acatalog/index.html Quote Link to comment Share on other sites More sharing options...
Guest Grim Reaper Posted October 30, 2003 Report Share Posted October 30, 2003 Are some of you guys dealers ? B)depends on what you want to buy!!!!!! :o :o :o :lol: Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted October 30, 2003 Report Share Posted October 30, 2003 ;) Quote Link to comment Share on other sites More sharing options...
Guest Grim Reaper Posted October 30, 2003 Report Share Posted October 30, 2003 http://www.rlsupplies.co.uk/item2479.htmrather decent case..... £27or£39.99http://www.rlsupplies.co.uk/item2484.htm Quote Link to comment Share on other sites More sharing options...
moon Posted October 30, 2003 Author Report Share Posted October 30, 2003 Right !! :D Got anything featureless, dull alloy, rubber feet with a front concealment door ? B) Quote Link to comment Share on other sites More sharing options...
Guest Grim Reaper Posted October 30, 2003 Report Share Posted October 30, 2003 http://www.rlsupplies.co.uk/item2480.htm £27 again....dull....but no concealment door..... Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted October 30, 2003 Report Share Posted October 30, 2003 this is nice ATX Zorro Case Silver Zorro - Silver:Drive bays 4x5.25",2x3.5",4x3.5" Internal fan:3 two ball bearing fans included M/B type: ATX & Pentium 4 (MAX SIZE: 12"x9.6") Front USB2.0 + Firewire + Audio See Through Window Side + Coloured LED Fan 450W DUAL Fan PSU *** CASE ONLY *** Price: £45.95 £53.99 Including VAT at 17.5%http://www.autdirect.co.uk/acatalog/index.html Quote Link to comment Share on other sites More sharing options...
Guest Grim Reaper Posted October 30, 2003 Report Share Posted October 30, 2003 How about this.............http://www.rlsupplies.co.uk/item1661.htmAsus A7V8X-X-Lan Socket-A Motherboard £40.95 -------------------------------------------------------------------------------- The ASUS A7V8X-Lan motherboard is loaded with the most advanced technologies to deliver maximum performance for Socket A processors. Based on the advanced VIA® KT400 chipset with DDR 400 support, the ASUS A7V8X also features AGP8X, USB 2.0 as well as 6-channel audio and LAN. Unique ASUS features such as ASUS C.O.P., Q-Fan, and MyLogo2 and more are included to ensure the best user experience and value in a motherboard. Features: Support all Socket-A Athlon/Duron Processors VIA KT400 Northbridge & VT8235 Southbridge Supports 200,266 & Future 333Mhz Front Side Bus Processors Supports up to 3Gb of DDR400/333/266 DDR Ram 1 x 8x AGP & 6 x PCI Slots 2 Channel UDMA133/100/66 IDE Controllers support up to 4 IDE Devices Realtek 6-CHannel Audio Codec with SPDIF In/Out On-Board 10/100 Network Adaptor (Broadband Ready) 6 x USB2.0 Ports with................http://www.rlsupplies.co.uk/item2336.htmAMD Athlon XP2500+ 333MHz FSB Barton (1.833GHz) £59.95 -------------------------------------------------------------------------------- nicely under budget.............better graphics card here you come!! Quote Link to comment Share on other sites More sharing options...
moon Posted October 30, 2003 Author Report Share Posted October 30, 2003 Geez !! Where are you guys coming from ? My head's reeling :DOK, it's for Rosi to carry out the graphics work around the gallery. Elegant case required. It's got to absolutely eat Photoshop work without belching, not so much as an hour glass or I'm toast. Where am I looking ? :blink: :D Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted October 30, 2003 Report Share Posted October 30, 2003 nice board here http://www.overclockers.co.uk/acatalog/Onl...ek_Only_25.html Quote Link to comment Share on other sites More sharing options...
Guest Grim Reaper Posted October 30, 2003 Report Share Posted October 30, 2003 yeah, the problem is looking at all this shiny new stuff makes us want to build again....... Quote Link to comment Share on other sites More sharing options...
Guest Grim Reaper Posted October 30, 2003 Report Share Posted October 30, 2003 nice board here http://www.overclockers.co.uk/acatalog/Onl...ek_Only_25.htmlthat is nice....... Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted October 30, 2003 Report Share Posted October 30, 2003 yeah let us build it moon then send it on to you B) Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted October 30, 2003 Report Share Posted October 30, 2003 yeah its a special this week only,full specs http://www.abit-usa.com/products/mb/produc...ories=1&model=8 Quote Link to comment Share on other sites More sharing options...
