Taaha Posted April 9, 2020 Report Share Posted April 9, 2020 Hi I am using 1TB Core i5 7th Generation how much ram I need to use for? Quote Link to comment Share on other sites More sharing options...
Belatucadrus Posted April 9, 2020 Report Share Posted April 9, 2020 RAM requirements depend on what programs you will be running, have a look on their web pages and check out the RAM requirements of each. Total up the figures for whatever you're likely to run simultaneously and that'll give you the bare minimum. Quote Link to comment Share on other sites More sharing options...
Taaha Posted April 14, 2020 Author Report Share Posted April 14, 2020 Thank You Quote Link to comment Share on other sites More sharing options...
pewpewmarc Posted May 31, 2022 Report Share Posted May 31, 2022 Do you use your pc for gaming and working? If that is so, then you should at least have 16GB RAM, that is also enough ram for streamers. 8GB is also fine, but for a smoother experience especially in gaming, it would be good to have 16Gb ram 🙂 Quote Link to comment Share on other sites More sharing options...
Graham45 Posted March 24, 2023 Report Share Posted March 24, 2023 As per your system configuration, you should have atleast 16 GB RAM. Also, RAM requirement depends totally on the kind of applications you use. You can check your system performance by visiting the task manager. Check if the RAM usages touch the 100%, you should consider upgrading the RAM. Quote Link to comment Share on other sites More sharing options...
