Craig Posted December 30, 2003 Report Share Posted December 30, 2003 Hi all,I'm after a multi region DVD player. I like the look of the small DVD players, but am put off them as they dont have a display.I have seen some LG DVD players, but they dont seem to be multi region. Does anyone know of a place where i can buy a multi region LG DVD player or know of somewhere i can get it hacked?! Quote Link to comment Share on other sites More sharing options...
Sir Radfordin Posted December 30, 2003 Report Share Posted December 30, 2003 If you can get in at PCA have a look here:http://www.pcadvisor.co.uk/index.cfm?go=di...22774&forumid=2Someone asked about this: http://www.whsmith.co.uk/whs/go.asp?isbn=CHDVD400&DB=622And the Wizard posted this:Have had one for 6 months and it is superb. It wil play music CDs, do slide shows from CDs and there is a simple hack that will make it multi-regional ;-))))) click here and the main page (Germany) is at click here To save you trawling the hack is as follows....1. Press the Open/Close button on your remote control to open the drive tray 2. Press the Setup button on your remote control 3. Using your remote control, highlight but do not select the Exit Setup option in the menu 4. Press the buttons 1, 3, 6 and 9 on your remote control, in order, one at a time 5. Press the Left button on your remote control, three times, in succession 6. Press the Right button on your remote control 7. Select the new Version option from the menu 8. You will now be able to change the value to 1 for Region 1, 2 for Region 2, and so on, or 0 for multi-region playback The links are:http://forum.cyberhome-dvd-help.com/http://www.cyberhome-help.de/cyberhome-help.html Quote Link to comment Share on other sites More sharing options...
Boris Posted December 30, 2003 Report Share Posted December 30, 2003 I bought a Ronin P215 last Friday £49.95 - really impressed with the quality.Dimensions 300mm (W) x 65mm (H) x 280mm (D)RONIN P215 MIDI MULTI-REGION 2.1 SILVER DVD PLAYER. DVD player features: Disc Compatibility: DVD, CD, MP3, VCD, SVCD, CD-R, CD-RW, DVD-R & DVD-RW MP3 & JPEG On Screen Viewer. (Including Directory Structure), Built In digital 2.1 Dolby Decoder, Video Advantage, Video Compression MPEG-2 (ISO/IEC-13818), MPEG-1, 12-bit Video Decoding, PAL, NTSC Playback, Selectable Screen Aspect Ratio (4:3 & 16:9), Smart Video (Sharpness, Contrast, Brightness), Multi Angled View, Multi Language OSD (8 bit On Screen Display), Multilingual Dialogue up to 8 tracks and 32 subtitles, Multi Speed FF./RW, Slow Motion & Multi Level Zoom, Supplied with instructions and code to covert the player to Multi-RegionGot mine from :-http://ukdvdplayers.co.uk/h_GG9403-dvd-player.htmlSpecial Reserve Shop in Bristol (Gloucester Road)They got 5* reviews at e-buyer - but none in stock now ? Quote Link to comment Share on other sites More sharing options...
Damo Posted December 31, 2003 Report Share Posted December 31, 2003 I bought my dvd a few years back just before they took off, its a samsung dvd-709 and cost me best part of £350! it only played region 2 but I found a hack on the net and now its multi region!!!! :D Quote Link to comment Share on other sites More sharing options...
Craig Posted December 31, 2003 Author Report Share Posted December 31, 2003 Does the "CyberHome CH 400" from WH Smiths have a scart output? Quote Link to comment Share on other sites More sharing options...
Sir Radfordin Posted December 31, 2003 Report Share Posted December 31, 2003 http://www.whsmith.co.uk/whs/go.asp?ISBN=CHDVD400&DB=622Synopsis Amazing value, slimline DVD player from the reliable CyberHome brand. Also plays MP3, CD-R, Video CD and Super Video CD. Delivery limited to UK credit card billing addresses. Special Playing FunctionsQuick and Slow Forward / Backward PlayRepeat Section A to B, 1/AllRating LevelMulti Language (depends on title)Subtitle (depends on title)Multi Angle (depends on title)16:9 / 4:3 TV Screen SelectionMP3 PlaylistPlayback RepeatZoom-In and Zoom-Out FunctionScart connection available but scart lead must be purchased separately. Quote Link to comment Share on other sites More sharing options...
Boris Posted December 31, 2003 Report Share Posted December 31, 2003 CraigLook in Richer Sounds in Cheltenham ? Quote Link to comment Share on other sites More sharing options...
Craig Posted December 31, 2003 Author Report Share Posted December 31, 2003 CraigLook in Richer Sounds in Cheltenham ?I havent, but i have ordered the DVD player from WHS.Hopefully it will arrive at the same time as my new LCD TV! :D Quote Link to comment Share on other sites More sharing options...
