CD-RW and DVD-ROM
Hi folks
I have this intermittant fault
Only sometimes and i mean once in a blue moon my CD-RW and DVD-ROM are not recognised at all.
It happens sometimes when i go into the BIOS to set the CDRW as 1st boot and only sometimes it sais no drive(or disabled)
Its starting to bug me, didnt think i would say anything as at 1st i thought it was me and then way i set the PC up, but i know its not me
Any ideas.
AMD 2200XP. 512MBDDR RAM. 40GB HDD(MASTER). 20GB(SLAVE). GEFORCE 64MBDDR GRAPHICS. ZIP DRIVE. CDRW DRIVE. AND A DVD ROM DRIVE
P.S dvdrom and cdrw on ide 2
Just a thought, make sure all the connectors are pushed home. I recently had some very odd happenings with a hard disk (not being seen, told it was 203GB when it's only 40, etc.)
All cured by pushing the IDE plug back in properly. It didn't appear to be loose and I don't know how it came to be loose but it was.
madboy seeing as I have the same setup as you on my second puter,nforce etc,I must admit to never having that problem,only difference is I have my dvdrom as master on ide2 and cdrw as slave,a lot of bios prefer it that way,if it becomes a problem change them over if makes no difference for burning I have found if the cdrw is on slave.
Will give that a bash at the weekend ellas
thanks alot
I loaded driver (a game ) yesterday and the computer just kept on re-starting all the time!
Lucky i had Drive Image to go back to a previous time
I cant put my finger on why the comp restarted? would the game have made a serious error like this?
p.s i checked the computer for viruses etc etc
