Port 5 not open
Not sure if this is the right section for this
Checking out with Sandra and the Port closed came up.Cant see anything (understandable) on Google for it..........What does it mean?
It also suggested I reduce colour to 16 bit And higher the refresh rate to 75Hz - which I have - now I'm wondering if I should have?
Guest Lived Backwards
Sisoft Sandra is notoriously unreliable......
Not sure about port 5 but i would increase colour back to 32bit, which refresh rate were you using? Use the maximum that your monitor will support.
75 is the maximum.
I'll change the colour back then.
As regards the port 5 - I haven't had any problems.............
