trackrat Posted February 29, 2004 Report Share Posted February 29, 2004 I have 2 computers that I want to network together they are next to one another so a cabled network will do.I have been reading about the different types 11b 11g etc can anyone advise me what is best and what sort of cards I should fit.Regards Alan Link to comment Share on other sites More sharing options...
Guest Blink_182_fan Posted February 29, 2004 Report Share Posted February 29, 2004 do yo have bband trackrat as if you do to get the full 512 b sent by your bband modem you would need to get a 54mbps network, well thats what ill be soon doing except with a wireless network Link to comment Share on other sites More sharing options...
Chris Posted February 29, 2004 Report Share Posted February 29, 2004 The 'b' and 'g' refer to wireless networking with 'b' giving 11Mbps and 'g' 54.Look at what our chris came up with here. Link to comment Share on other sites More sharing options...
trackrat Posted February 29, 2004 Author Report Share Posted February 29, 2004 Thanks for that Powerless, also reading Blinks reply it looks like I need the G variant as I have BB.Another question -- my cable modem plugs into the lan connector, but on the other machine the lan connector is available so does this mean I only have to purchase one network card? or is`nt it that simple. Link to comment Share on other sites More sharing options...
Chris Posted February 29, 2004 Report Share Posted February 29, 2004 Your getting confused [or maybe it's me?].You said "I have 2 computers that I want to network together they are next to one another so a cabled network will do."Now the b and g refer to a Wireless Network, in other words no wires.Chris will tell you what to do from now...Cable :o Link to comment Share on other sites More sharing options...
trackrat Posted February 29, 2004 Author Report Share Posted February 29, 2004 No Powerless you are not getting confused it is just me showing my ignorance Link to comment Share on other sites More sharing options...
spikeychris Posted February 29, 2004 Report Share Posted February 29, 2004 Don't know if you want it opened again but just to point out, you would need more than one LAN point if you want to share the net as well as files and folders. As you have figured, 8021b 8021g refer to wifi and seeing as your machines are side by side its pointless going the wifi route.Either shove a router in the middle of them of if you have a USB modem use that on the host machine and run a x over cable to the other machine or shove 2 cards in the host and run a cable from one and use the other for the modem.Chris Link to comment Share on other sites More sharing options...
trackrat Posted February 29, 2004 Author Report Share Posted February 29, 2004 Thanks Chris, the cable modem is connected to the lan port, would it be better to buy 2 cards or a router.Which would be the easiest to set up.Regards Alan Link to comment Share on other sites More sharing options...
spikeychris Posted February 29, 2004 Report Share Posted February 29, 2004 Do you have a USB modem? if not the easiest and cheapest way is to install two cards on the host. Its still easy with a router though and they are getting cheaper by the day. Click here and follow the links at the bottom of the screen for a fantastic guide. Link to comment Share on other sites More sharing options...
