gunn Posted March 31, 2004 Report Share Posted March 31, 2004 helo...i just wonder how to delete 'setting' in start menu?? because i need to do some protection of shared computer......thank you very much Quote Link to comment Share on other sites More sharing options...
Intratech Posted March 31, 2004 Report Share Posted March 31, 2004 Right click on taskbar|| Properties || Start Menu || Customise Quote Link to comment Share on other sites More sharing options...
gunn Posted April 3, 2004 Author Report Share Posted April 3, 2004 how can i disable pop-up(right click) in tack bar?? because if i disable the setting(i mean is control panel) in start menu, it will be useless if they still can access through properties......Thank's Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted April 3, 2004 Report Share Posted April 3, 2004 you need something like Tweak UI http://www.microsoft.com/windowsxp/pro/dow...s/powertoys.asp Quote Link to comment Share on other sites More sharing options...
Agent Smith Posted April 3, 2004 Report Share Posted April 3, 2004 Why not create a security template (also known as a policy) and assign it to the user.You can control pretty much anything from there.Mr. Mouse. Quote Link to comment Share on other sites More sharing options...
Chris Posted April 4, 2004 Report Share Posted April 4, 2004 Why not create a security template (also known as a policy) and assign it to the user.You can control pretty much anything from there.Mr. Mouse.Only for XP Pro. Quote Link to comment Share on other sites More sharing options...
