Guest Blink_182_fan Posted April 5, 2004 Report Share Posted April 5, 2004 My bt broadband has been running very slow and when i started to download a file it went from the normal speed down to 12.1kbps and its decreasing very slowly and i dont know why. I only have that download and one IE window open. Quote Link to comment Share on other sites More sharing options...
Andy-2004 Posted April 5, 2004 Report Share Posted April 5, 2004 I have already told blink to do this in IM but wouldn't i be right in saying that rebooting is the first thing you should do to try and fix this? Quote Link to comment Share on other sites More sharing options...
trackrat Posted April 5, 2004 Report Share Posted April 5, 2004 Blink run this test, if it finds any faults you will be able to print a report to use if you need one.http://www.vantage.pwp.blueyonder.co.uk/v2/v2.htm Quote Link to comment Share on other sites More sharing options...
Guest Blink_182_fan Posted April 5, 2004 Report Share Posted April 5, 2004 its wasnt my broadband at all it was to do with the site i was downloading off Quote Link to comment Share on other sites More sharing options...
Andy-2004 Posted April 5, 2004 Report Share Posted April 5, 2004 are you still having the problem....And is it true that if you have Normal 512 BT BB that you share your Bandwidth with up to 50 ppl living near you? Quote Link to comment Share on other sites More sharing options...
djohn Posted April 6, 2004 Report Share Posted April 6, 2004 Hi Andy. If I've understood correctly it's not how many people living near you but how many people are allowed to share your connection to your ISP. So if your ISP is using a contention ratio of 50-1 that is the maximum amount of people that should be allowed on your connection at any one time. Generally there are far less.Some ISP's will use this to their advantage and allow say, 60 or "more!" connections knowing full well that the odds of all 60 being on-line and downloading at the same time are quite small but it can happen and then your connection speed will really slow down.The better ISP's will stick to the contention ratio they have promised you on signing up for their service. Some ISP's especially the one's that are trying to build up a large customer base by giving free months or reduced price for the first x months and advertising this on the telly may be oversubscribed at certain periods of the year when many people are joining, not adding additional servers to cope with the demand. [They won't install extra capacity until they are sure people are staying with them.] Have you ever heard of an ISP that says, "Sorry we can't take you on at the moment, we have too many customers" :rolleyes:I may be wrong with this explanation but if I am, others will correct. :unsure: Quote Link to comment Share on other sites More sharing options...
