Case problems
Guest Blink_182_fan
Guest Blink_182_fan
Ok Andy got his new case and he put everything in but he says when it is loading up and checking the processor and memory it says ok and then freezes.
If my memory was right, he was also getting a new zalman heatsink and fan combined. He may need to check the bios to make sure it is not set to look for an active fan. It is possible the 92mm fan on his zalman will register as turning to slowly for the bios to boot.
If he has fitted the inline speed switch for the fan, tell him to remove that as well.
Mr. M.
