pllllz help SOS :((
hi
I bought a ram and it has a problem when I installed it on pc and I get it away and there's a problem at first time when I rebooted my pc windows not booted and display show a black screen with no cursor and the pc completly hanged! and i try install windows 98 and in setup it hang and I try install windows xp and when I boot my computer from setup cd when it boot again the black screen apear and I try recovery my files with ntfs recovery but it occur a error: error reading # 0 sector or invalid boot sector plllllllllllllllz help meeee I NEED MY FILES IN NTFS DRIVE THEY ARE VERY IMPORTANT FOR ME!!!
You cannot boot your computer?
If this is the problem, insert your XP CD, boot from it, and go to recovery console (type r when it's done loading)
Log on to the installation you have as your main partition, type your admin password, and then you should be at a C: prompt.
type 'fixboot' and 'fixmbr'
If this isn't the problem your having, please give more details as to what happened, and what you would like to do.
  • 1 month later...
