Blink_182_fan Posted August 10, 2004 Report Share Posted August 10, 2004 Ok Today when i got home i tried to access the net of my wireless network but it didnt work, Although it says that im getting a signal i cant get on messenger, sites etc. My other computer that is connected by a LAN card and network cable is working fine as i m posting this message off it.I think its something to do with my Wireless PCI card so im going to remove it and take it back but i'd though i'd post here first incase it was something else Quote Link to comment Share on other sites More sharing options...
expertec Posted August 10, 2004 Report Share Posted August 10, 2004 You tried uninstalling and re-installing the wireless card's drivers? Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted August 10, 2004 Report Share Posted August 10, 2004 All wireless products come with a setup CD that must be installed before connecting any hardware.Remove your hardware, remove the software, re-install the software then reinstall the hardware. If you have any problems, consult your documentation.Wirelss is very picky, if anything is not installed 100% correct, it won't work. Quote Link to comment Share on other sites More sharing options...
Blink_182_fan Posted August 10, 2004 Author Report Share Posted August 10, 2004 its been working for about 1month-2 months but ill reinstall the drivers for the pci card Quote Link to comment Share on other sites More sharing options...
Besty Posted August 10, 2004 Report Share Posted August 10, 2004 Just try replugging everything again Quote Link to comment Share on other sites More sharing options...
Blink_182_fan Posted August 10, 2004 Author Report Share Posted August 10, 2004 Ok its not working just going to take it back and hope for the best Quote Link to comment Share on other sites More sharing options...
Blink_182_fan Posted August 10, 2004 Author Report Share Posted August 10, 2004 ok i got a new card still no joy :(. If anyone knows what might be wrong i would really appreciate there help. Its either a fault in the router or my computer. Ill try and get a hjt log posted asap Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted August 10, 2004 Report Share Posted August 10, 2004 It's probably not a HJT issue.Make sure your default gateway and DNS are set up. IP can be done through DHCP. Quote Link to comment Share on other sites More sharing options...
Blink_182_fan Posted August 10, 2004 Author Report Share Posted August 10, 2004 I havnt changed anything and it was working Quote Link to comment Share on other sites More sharing options...
Redhat Posted August 10, 2004 Report Share Posted August 10, 2004 Start > Run > CMD > ipconfig /all Please post the response :) Quote Link to comment Share on other sites More sharing options...
Blink_182_fan Posted August 10, 2004 Author Report Share Posted August 10, 2004 lol, ok im going to stop turing my other comp off now Quote Link to comment Share on other sites More sharing options...
Blink_182_fan Posted August 10, 2004 Author Report Share Posted August 10, 2004 ok ignore my last post. Quote Link to comment Share on other sites More sharing options...
Redhat Posted August 10, 2004 Report Share Posted August 10, 2004 Try : ipconfig /releasethen ipconfig /renew Reboot, and then see if anything changed. Quote Link to comment Share on other sites More sharing options...
Blink_182_fan Posted August 10, 2004 Author Report Share Posted August 10, 2004 on what computer? :huh: Quote Link to comment Share on other sites More sharing options...
Blink_182_fan Posted August 10, 2004 Author Report Share Posted August 10, 2004 on the computer with the router i got error connecting to local area network access is denied Quote Link to comment Share on other sites More sharing options...
Blink_182_fan Posted August 10, 2004 Author Report Share Posted August 10, 2004 on comp with pci card"Operations can not be done on local area network when media is disconnected"It was something along the lines of that Quote Link to comment Share on other sites More sharing options...
Besty Posted August 10, 2004 Report Share Posted August 10, 2004 Have u installed or uninstalled anything just before the problems Quote Link to comment Share on other sites More sharing options...
Blink_182_fan Posted August 11, 2004 Author Report Share Posted August 11, 2004 nope Quote Link to comment Share on other sites More sharing options...
Blink_182_fan Posted August 11, 2004 Author Report Share Posted August 11, 2004 any body got any other ideas?? Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted August 11, 2004 Report Share Posted August 11, 2004 Check services?go to Run, and type services /msc turn off wireless configuration, and use the setup disks to conifgure it. Quote Link to comment Share on other sites More sharing options...
Blink_182_fan Posted August 11, 2004 Author Report Share Posted August 11, 2004 on what computer? Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted August 11, 2004 Report Share Posted August 11, 2004 the one with the problem.If services /msc doesn't work, try going to control panel, administrative tools and look for services. Quote Link to comment Share on other sites More sharing options...
Blink_182_fan Posted August 11, 2004 Author Report Share Posted August 11, 2004 is this to stop win xp from configuring the card becuase ive already done it Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted August 11, 2004 Report Share Posted August 11, 2004 Yea.. Wireless Zero Configuration or something like that.I don't know what to tell you blink. Sounds like you've tried everything I would have done. Quote Link to comment Share on other sites More sharing options...
Blink_182_fan Posted August 11, 2004 Author Report Share Posted August 11, 2004 ok if nothing else works im going to take router back and if still not luck im goignt oask for cash and get a differnt router etc... Quote Link to comment Share on other sites More sharing options...
