brandyAJ Posted September 16, 2004 Report Share Posted September 16, 2004 I have tried to install SP2 and twice it has restarted my computer and just loops(starts to come up and then restarts). I have had to reinstall XP and now my computer acts funny ie. slower,doesn't scroll smoothly. I made sure there were no viruses or spyware or adware, all of the extra programs it said would conflict, I took off. What is going on? Quote Link to comment Share on other sites More sharing options...
Rebel=UK= Posted September 16, 2004 Report Share Posted September 16, 2004 u tried updating your graphics card drivers? Quote Link to comment Share on other sites More sharing options...
brandyAJ Posted September 16, 2004 Author Report Share Posted September 16, 2004 Actually, no I haven't. Would that be it? Quote Link to comment Share on other sites More sharing options...
andsome Posted September 17, 2004 Report Share Posted September 17, 2004 This is no help to you of course. I am puzzled why an update of drivers is OFTEN suggested as a solution to a problem. Surely if the drivers are running a program or component OK today, they should also do so tomorrow, or have I missed something? Quote Link to comment Share on other sites More sharing options...
bluesman821 Posted September 17, 2004 Report Share Posted September 17, 2004 I too tried installing SP2 and the same thing occured.I had to use True Image Recovery. I would be interested in any solution to this as I would like to install SP2. Quote Link to comment Share on other sites More sharing options...
artist Posted September 17, 2004 Report Share Posted September 17, 2004 I read through the SP2 forum on PCA and in a nutshell this is what I did:I had already done a virus scan the previous day.1. Run a spyware check2. Run disc clean up3. Make a restore point4. Disable - virus chechecker spyware checker firewall cookie cruncherthen close all running programmes.5. run the disc.Restart computerI'm using the MS firewall now.So far - all is fine. Quote Link to comment Share on other sites More sharing options...
pacman123 Posted September 21, 2004 Report Share Posted September 21, 2004 Downloaded sp2 today, did all Artist has posted except left AV running,downloaded from win updates no problems, now running xp firewall along with sygate no conflicts as of yet will report back if any occur...... Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted September 21, 2004 Report Share Posted September 21, 2004 Actually, no I haven't. Would that be it?Always worth a try.This is no help to you of course. I am puzzled why an update of drivers is OFTEN suggested as a solution to a problem. Surely if the drivers are running a program or component OK today, they should also do so tomorrow, or have I missed something?Oh, it's possible.. Computers only do what they are told to do, but people tell them to do some pretty funny things if they aren't sure what thier doing.... :P Quote Link to comment Share on other sites More sharing options...
Besty Posted September 22, 2004 Report Share Posted September 22, 2004 Is there any way of uninstalling sp2 Quote Link to comment Share on other sites More sharing options...
bvw Posted September 22, 2004 Report Share Posted September 22, 2004 Is there any way of uninstalling sp2Add/remove in Control Panel Besty. Quote Link to comment Share on other sites More sharing options...
