homecomputeraid Posted October 17, 2004 Report Share Posted October 17, 2004 I know I'm pretty new to the forum, but I'd like to share a little based on the questions I've seen.PLEASE, no one take offense if this is too simplistic! I'm sure there are many in these forums that have more networking experience than I. I'm writing this for people who are new to networking. :)I'm going to break this up into parts instead of trying to put it all into one post. That way, you can be bored to tears (or on the edge of your seat?) :) in relatively small chunks, instead of all at once!What's a Network?A Network (I'll start with a Local Area Network) is two or more computers connected to each other most often using Ethernet, and Category 5 (or 5e) Cabling, or 802.11g Wireless. A LAN can be used to share resources, like that precious Internet connection, printers, and to let you move information between your own computers. How do you build a network?In order to make two PC's "talk" over a network, each PC must have at a minimum, three things:1. A Network Interface Card (NIC): Most likely (99.999% of the time) an Ethernet wired or wireless NIC.2. A Protocol: Almost always TCP/IP.3. A Client: For home users, almost always Microsoft Family Logon. Included in Client Configuration, is making sure all PC's that want to connect to each other are in the same Workgroup or Domain.NICWired or Wireless?A Wired NIC should be a 10/100 Megabit Ethernet PCI Card (Gigabit Ethernet has become quite inexpensive, if you want a very fast connection between PC's). Here's a 10/100 NIC by Netgear, available from Tiger Direct for $15.99.A Wireless NIC should be an 802.11g Wireless PCI NIC, like this one from D-Link for about $50.00.Above, I said you'd want PCI Cards, but for a laptop, of course, you'll want PCMCIA (PC Card) NIC's. A Laptop Wired NIC like this Netgear PC Card NIC is available from CompUSA for $39.99. Here's a PC Card Wireless Linksys 802.11g from CDW for $67.07. (Sorry to my European Readers, but all prices are in U.S. $)Once your NIC is installed, (you must physically install the card, and make sure the software Drivers are installed correctly) you'll be able to "bind" a protocol to it.PROTOCOLThe Protocol you use will be TCP/IP if you want to connect to the Internet. On some older Operating Systems, NetBEUI and/or IPX/SPX are on by default. I recommend turning those protocols off for home networks.You're in luck! The Drivers for most network cards install TCP/IP for you! :)To check what Protocols are installed, do the following:Windows 98/Me:Right click on Network Neighborhood (neighbourhood?) :) on your desktop, and select Properties from the menu that comes up. Under the Configuration Tab, scroll down and make sure TCP/IP -> Your Network Adapter (your adapter name will be here) appears.Windows XP(2000): Click on Start, Control Panel. In Control Panel, click on Network & Internet Connections, then on Network Connections. (2000, just right click My Network Places on your desktop, then select Properties).Right Click on Local Area Connection and choose Properties. Make sure Internet Protocol (TCP/IP) is listed. I'll have much more (more than you want to know?) about TCP/IP in Part 2.If your NIC is installed correctly, TCP/IP should be there. If it isn't, in the Network window you can click on Add, select Protocol from the Select Network Component Type window, click Add, click Microsoft in the left pane, and scroll down to TCP/IP in the right pane, then click Ok. If you don't know where your cab files are on the Hard Drive, you may need your Operating System CD for this.CLIENTLike TCP/IP, a Microsoft Client should be installed with the NIC Drivers. To check your Client:Windows 98/Me:Right click on Network Neighborhood on your desktop, and select Properties from the menu that comes up. Under the Configuration Tab, scroll down and make sure TCP/IP -> Your Network Adapter (your adapter name will be here) appears.Windows XP(2000): Click on Start, Control Panel. In Control Panel, click on Network & Internet Connections, then on Network Connections. (2000, just right click My Network Places on your desktop, then select Properties).Right Click on Local Area Connection and choose Properties. Make sure Microsoft Family Logon is there. You can use the Client for Microsoft Networks, but you'll want to make sure the Client is NOT set to logon to a Windows Domain, if you don't have your own Server (most home users do not). To do this, in the Network window as above, select Client for Microsoft Networks, and click Properties. In the Client for Microsoft Networks Properties window, make sure Log on to Windows Domain under Logon validation is unchecked. WorkgroupWow! Did I say I was going to break this up into small chunks? Sorry it's turning out sooo long. I'm typing my fingers numb!Ok, one last piece to the puzzle, the workgroup. In order for your computers to access each other's resources, they will have to either be in the same Domain (primarily used for corporate networks) or workgroup (the home user’s choice). To check your Workgroup:Windows 98/Me:Right click Network Neighbourhood, and select Properties. Click on the Identification tab. You'll see your Computer Name and Workgroup. Write them down. The Computer Name must be unique throughout your network and should be something meaningful to you (Kitchen, Laptop, something). The Workgroup name must be the same for all the computers you want to communicate with each other. The name isn't important, as long as it's the same throughout your network. Windows XP/2000: Right click on My Computer and select Properties. Click on the Network Identification Tab. Follow the same rules as above for naming the Computer and Workgroup. Well, if you made it through all that, congratulations! :)I hope it's helpful with some of the fundamentals!Once my typing fingers heal, I'll post on TCP/IP, and Routers/Firewalls (if this post is well received) :)Sincerely, Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted October 17, 2004 Report Share Posted October 17, 2004 Pinned. :D Quote Link to comment Share on other sites More sharing options...
homecomputeraid Posted October 17, 2004 Author Report Share Posted October 17, 2004 Thanks Scarecrowman!Sincerely, Quote Link to comment Share on other sites More sharing options...
-pops- Posted October 17, 2004 Report Share Posted October 17, 2004 Looks good :) Waiting for part 2. Quote Link to comment Share on other sites More sharing options...
homecomputeraid Posted October 18, 2004 Author Report Share Posted October 18, 2004 Part 2's up Pops.Could you, or Scarecrow Man, or someone pin it? I asked Nell, but I don't know when she'll get to it, or how to go about asking someone.Sincerely, Quote Link to comment Share on other sites More sharing options...
scuzzman Posted February 15, 2005 Report Share Posted February 15, 2005 Just so we've got the link in a pinned topic:If anyone is reading this troubleshooting a home network, I recently took someone through a rather in-depth networking troubleshooting session I think might be beneficial. The link is here. Quote Link to comment Share on other sites More sharing options...
homecomputeraid Posted February 15, 2005 Author Report Share Posted February 15, 2005 Thanks John,Great work.Ted Quote Link to comment Share on other sites More sharing options...
blackrose Posted October 11, 2013 Report Share Posted October 11, 2013 I like this forum..... It is great...... and much informative..... Thanks alot.... Quote Link to comment Share on other sites More sharing options...
