No sound in video
Tony
Hi all
I have been transfering video from my sony digital camcorder to my second PC running win 2000.
The video is being captured in AVI format, which is fine, i have already converted some of them to DVD with no problems.
But i also want to keep a backup of the RAW avi file that is created when the video is captured., so i am burning them to DVD just as data (so it is just an .avi file on the DVD) this is fine, but when i put the burnt disk into my XP machine, i get NO sound when i play the video back, i have tried win meadia player, plus a few others but all the same result.
I put the burnt disk back into the win 2000 system and the sound is there, so i am guessing that it is some sort of codec problem on my xp system, but how do i find out what one it needs? the xp system has loads of codecs installed already, and this is the first video i have had this result with.
Any ideas what the problem is?
Cheers
Tony
Hi mark
This is what G-spot tells me it looks like it can't find the audio stream
And after asking it to render the file this is what pops up
Do you understand it cos i don't :unsure:
The sound is on the burnt DVD cos when i put it back in the win 2000 system it works
Cheers
Tony
Hi mark
Cheers
Tony
not sure I understand why either, other than the reference to unsupported format in rendering,
I might possibly be barking up the wrong tree, check to see if you have the AC3 codec installed on either machine, ( this is purely a hunch, had an AVI file that required it before, I'm guessing it may be missing on the XP, something rings a bell in the back of my mind)
