Problem installing Cyberhome dvd-r/-rw writer
I got a Cyberhome DVD burner for christmas, and I didnt know anything about installing them, but i tried anyway before i begged someone for a free installation. I thought I had it figured out. Took the IDE wire thing that came from my top drive ( im not sure if im saying this right, so please correct me if im a dumbass) and put that into the back of the burner, and the power thing that was connected to the cords from the top drive. The burner also came with an audio cord, and i dont know what to do with that one. I just plugged it into something that looked right enough. So then i turn the computer on, and i log into XP and it freezes shortly after starting windows. I didnt know what that the problem was. I undid what i did with the burner and turned it on and it works fine. Could it be beause the top drive isnt set to slave? no idea
PS Dell computers towers make it impossible to screw the screws into the sides. You cant get all the sides off. Anyone have a 2400 with the metal shell thing and know how to get the other side off? or any other pieces off that make it hard to do? its a pain in the ass.
Thanks guys, any help whatsoever is greatly appreciated.
and also i didnt just do this once, i did it a bunch of times and it kept freezing (takin the audio cord out, in etc) still didnt work.
Maybe this is the problem: my top drive is cd rom only, and im going to buy a dvd rom probably this week, but i wanted to install the dvd burner because i had it. And the ide cable is FIRST connected to the CD ROM top drive, and the other connector on the same cord is connected to the DVD burner. I tried just plugging everything in while the computer was on, and the drive opens and shuts and stuff, but XP doesnt seem to recognize it. should i try restarting it now?
ps... Where is the audio cable supposed to go? Cyberhome has some pretty s***ty instructions....and thanks for all your help thus far! im close... i can feel it!
On the back of the drive there is a row of double pins with a plastic clip on two of them, some where it should have letters stamped on it ( M S CS )
M is master - S is slave - CS is cable select.
If their are no letters stamped above these pins have a look at the S*****y documentation.
Yes you can still keep it as a slave and set your new DVD rom as master, that is when you figure out how to get the CDrom out :P
SpiritualGorila
Which actual model Dell is it ?
http://reviews-zdnet.com.com/Dell_Dimensio...60.html?tag=tab - this one ?
Some have pairs of green plastic drive rails which lock the optical drives in with spring clips and can just be unsprung from the front - when you have removed the front fascia.
well its a Dimension 2400. Its new i got it this year, around may. i dont see anything green. They have little screw like things holding the frame together, but i dont see anything to unscrew them with. maybe on the inside? I dont have time, i have to go to work, but ill be back here in about 7 hours. Thanks for your time.
The drive rails may actually be made of metal and silver as well as green plastic ?
The rails are screwed to the actual optical drive - which then slots in from the front.
If you can remove the front fascia, you may be able to see the ends of the rails ? If you can ............ - either press them inward or outward (I can't remember which way !) to release the drive to enable it to slide out toward the front of the case ???
I figured it out finally. The top drive i have was set to cable select for some reason and i just couldnt see it, so i just switched the dvd burner to cable select, and presto, it works. Thanks everyone for all your help...
But one more query! Anyone know how to get the top drive out of a dell computer????? cuz i cant unscrew the screws at all..... wondering if theres a simpler way....
