Second Hard drive problems
Just installed a second hard drive.
Windows shows it as 250mb when it is actually 8.9gb.!
The drive came from an old Win NT machine, how do I format it and convert to fat 32? (it won't convert to FAT32 at the moment because windows says it;s too small)
Bios shows the drive and that it's slaved
Running 98SE
Here's a link which will create you a 98SE boot floppy
ftp://ftp.fluidlight.com/pub/nospin_files/WIN98SE.exe
Boot disk is a self extracting Image file.
Just place a floppy disk in your 'A' drive and execute the file.
It will format the floppy disk and then create your boot disk.
Oooooops ........................ that link doesn't work.
This one does !
http://chappy.phpwebhosting.com/Disks/win98.exe
To use, download the .exe file and double click on the downloaded file. This will write the appropriate files to a diskette. Before you write these files to a diskette, ensure that all Explorer windows are closed (including all My Computer, and A: windows).
Success :D
Don't know how but I'm there :P
Is it just me? using the links Nell posted I found walk through screen shots and the actual differed somewhat :blink:
Anyway deleted the partitions OK but could not create a primary partition as it already existed :blink:
Gave up and shut down :(
Boot up to day got a Norton message about not being able to access drive D.
On line checking Nell's links and suddenly I get a message, Drive D is not formatted do you wish to format drive D? YES!!! clicked format and Bobs your uncle :D
BTW used the windows run/ command to access fdisk the screen displayed is the same as that shown using a boot disc. Is there some reason to use a boot disc rather the the command prompt :blink:
