Scarecrow Man Posted February 4, 2005 Report Share Posted February 4, 2005 I was called to take a look at a computer. The user told me he could not read his e-mail. I figured it was a security setting or something like that.When I got there, I opened Outlook Express, and opened an e-mail. Upon opening it I noticed the sender, subject etc. were fine, but the message itself was not there.Not only is the message not there, but if you go to Edit > Select All, it only selects a few characters making me think this is not a font problem.I should also add that the user is able to recieve e-mails fine, and sending does not seem to be a problem either.It was also mentioned that if the user checks his hotmail account, the message cannot be seen there either.I have downloaded and re-installed Internet Explorer with no avail.Have any ideas? :unsure:EDIT: Click here for FULL re-install instructions Quote Link to comment Share on other sites More sharing options...
scuzzman Posted February 4, 2005 Report Share Posted February 4, 2005 Any way you could get us a screenshot? Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted February 4, 2005 Author Report Share Posted February 4, 2005 Yes. Give me a minute. Quote Link to comment Share on other sites More sharing options...
scuzzman Posted February 4, 2005 Report Share Posted February 4, 2005 Hmm... this si what I've found thus far: http://support.microsoft.com/default.aspx?...kb;en-us;312359 Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted February 4, 2005 Author Report Share Posted February 4, 2005 Hmm... this si what I've found thus far: http://support.microsoft.com/default.aspx?...kb;en-us;312359Oops. Sorry.Windows 98..... :unsure: Quote Link to comment Share on other sites More sharing options...
scuzzman Posted February 4, 2005 Report Share Posted February 4, 2005 Check this out:• You receive e-mail messages with a blank body and a blank Subject field in Outlook after you upgrade to Internet Explorer 6 for Windows 98(305464) - Describes a problem where you receive e-mail messages with a blank body and a blank Subject field in Outlook after you upgrade to Internet Explorer 6 for Windows 98.http://support.microsoft.com/default.aspx?...kb;en-us;305464 Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted February 4, 2005 Author Report Share Posted February 4, 2005 Will Internet Explorer 6 SP1 work with 98? Quote Link to comment Share on other sites More sharing options...
scuzzman Posted February 4, 2005 Report Share Posted February 4, 2005 Haven't heard the adverse... but there could be a conflict.. MS seems to think so... Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted February 4, 2005 Author Report Share Posted February 4, 2005 OK... Where can I download Internet Explorer.. the Admin InstallNot just the setup file, the full installation file. (the user is on dial-up and does not have a LAN card so I cannot download it at work) Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted February 4, 2005 Author Report Share Posted February 4, 2005 Here is a pic of the message you get after installing Internet Explorer, after pressing Edit > Select all. Quote Link to comment Share on other sites More sharing options...
scuzzman Posted February 4, 2005 Report Share Posted February 4, 2005 Well, that doesn't fully fit the solution I quoted - the Subject line is not blank... Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted February 4, 2005 Author Report Share Posted February 4, 2005 Never the less, I appreciate your help! :DI FIXED IT!!!!!!!!!!!!!!!!!!! :D :D :DHow?Give me a sec... Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted February 4, 2005 Author Report Share Posted February 4, 2005 http://www.msfn.org/articles.php?action=show&id=23I followed the instructions on that web page, put the folder on a flash drive, and installed.I should also add that it would seem the previous IE was corrupted, because when you go to Help > About, the version was not displayed. It acted like the messages having a blank spot where text should be.Anyways, the full install worked beautifully and I will have a very happy customer.Many thanks Scuzzman. I appreciate your help through this. :D Quote Link to comment Share on other sites More sharing options...
scuzzman Posted February 4, 2005 Report Share Posted February 4, 2005 Cool - glad you got it sorted :) Quote Link to comment Share on other sites More sharing options...
nellie2 Posted February 4, 2005 Report Share Posted February 4, 2005 What a team! :flowers: Quote Link to comment Share on other sites More sharing options...
