Wireless pci card + outdoor antenna
korgg
Hello ! Long time no see ... (unemployed mofo )
Back with a small question:
It might be some kind of stupid (at least), but can I connect an outdoor external antenna to a wireless NIC ??? The objective is to reach some point at about 700m .
I wanted to know if there is possible to avoid the purchase of an AP..
Thx !
God damn ! (please excuse me :D )
I'm not that dumb ! (at least I think I'm not ) :))
I just got an odd ideea that I could skip the buying of an AP... That's all ...
And I'm talking about antenna (external, outdoor) for wireless networking.. Yeap !
I cant find any reason not to, but it just doesn't seem right...
The project is simple...
I have a computer and a switch.. The distance between the computer and the switch is about 700m...I could go using repetears along the way (five of them ) and ftp cable.. But is so un-elegant... Or worse.. I could use fiber-optic cable...
The wirelss solution is the most elegant one and the most cheap...
Normally I could use two AP with outdoor external antaenas and my problem should be solved. About 300$ for everything...
But the question I asked intrigued me a bit ...
I don't think it's possible without an AP (Access Point?).
and I am still unclear as to what this "antenna (external, outdoor) for wireless networking" is... ?
I am under the impression that Wireless will not go 700m without the use of at least one access point (acting like a repeater)
AP is Access Point.. :)
Now.. Indoor antenna is the one that looks like a stick and you put it on your office...
Outdoor antenna is the one that looks like a TV one (mostly)... This one allows you to have a much bigger communication distance between AP's.
Now, since the big boss of my ISP is a good friend of mine, I allowed him to put an AP and an antenna in my house, and the distance between the this one and the client one was about 1000m... And it had quite a decent transfer...
I can get directional antenna for about 120$... Wich is not that expensive.
Netgear equipment is not that known around here... The brand I used to make the offer was Zyxel...
And I still cant imagine why can't I connect an outdoor antenna directly to the NIC ?? Could it be the signal strenght or what ? :(
