ugly fonts
Gagaman
I just installed win 2000 on an old laptop. Installation went smoothly, but the fonts are quite ugly. Some caracters seems to be bold, others not bold. See also the attached screenshot. Where can I change the fonts so they look nicer?
While taking the screenshot, I also noticed that I could only save it as .bmp, no other fileformats (like jpg or so) seem to be available. I used paint to save the screenshot.
EDIT: :blink: I just openend the attachment on my desktopputer... here the fonts look completely normal :blink: I assure you that on my lappy they look very ugly.... Sorry I cant show it here :(
gagaman try
1. Click Start, point to Settings, click Control Panel, and then double-click Display.
2. Click the Effects tab, click the "Smooth edges of screen fonts" check box, and then click OK .
The above applies to 98, 2000 I'd imagine would be something similar.
Clear Type was made for LCD Sreens, give it a go.
I use it even on my normal monitor, i prefer the effect.
Not sure if it is covered in win2000 help files, like it is in the xp ones, but you should be able to search for Clear Type in help.
Tony
gagaman try
Tried this, it does also applie to win 2000, but no change :(
Tony
Help doesnt tell about cleartype fonts, it does about truetype...
Gonna try it.
