trackrat Posted September 2, 2005 Report Share Posted September 2, 2005 Can you pu a pci ide controller card in a computer and disconnect the hard drive from the motherboard IDE controller and then connect it to the PCI card and use it to boot from.I am asking this as I suspect a faulty Mobo controllerSo by adding a pci IDE controller card will it be able to boot the main hard drive Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted September 2, 2005 Report Share Posted September 2, 2005 Yes. Promise Card.I hate them though.. wouldn't recomend it unless you have to.http://www.promise.com Quote Link to comment Share on other sites More sharing options...
trackrat Posted September 2, 2005 Author Report Share Posted September 2, 2005 SCMan how would you go about it, do you need to make any changes in the BIOS or just hook it up to the pci card and boot up?. Quote Link to comment Share on other sites More sharing options...
trackrat Posted September 3, 2005 Author Report Share Posted September 3, 2005 Anyone? Quote Link to comment Share on other sites More sharing options...
guestt03 Posted September 3, 2005 Report Share Posted September 3, 2005 yes you can. Either use the diskette supplied or download the software from the manufactures website.This will inform the bios to use the option to boot from the card, if the bios doesn't support that option yet.For a computer forum I am supprised no one ............. Quote Link to comment Share on other sites More sharing options...
trackrat Posted September 4, 2005 Author Report Share Posted September 4, 2005 guestt03 thanks for that reply. Quote Link to comment Share on other sites More sharing options...
-pops- Posted September 4, 2005 Report Share Posted September 4, 2005 It may be the controller in the hard drive that's the problem rather than the M/B. Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted September 5, 2005 Report Share Posted September 5, 2005 Sorry trackrat. Here is some more info:http://www.pcguide.com/ref/mbsys/buses/types/pciIDEBM-c.htmlThe card has it's own bios that will run after the computer bios runs. It will then continue to boot as normal. Quote Link to comment Share on other sites More sharing options...
trackrat Posted September 9, 2005 Author Report Share Posted September 9, 2005 Scarecrowman, after reading that I am glad I started on 98SE.It must have been fun in the 3.11 and 95 days. Quote Link to comment Share on other sites More sharing options...
