-pops- Posted November 4, 2005 Report Share Posted November 4, 2005 If you have Help Center missing as well as file compression, it makes me think there is something seriously wrong with your Windows installation. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted November 4, 2005 Author Report Share Posted November 4, 2005 Well, everything else works just fine :) The Help Center actually did work originally, but it was something by Dell, not original Windows. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted November 7, 2005 Author Report Share Posted November 7, 2005 http://support.microsoft.com/default.aspx?...kb;en-us;306531Just found this; it seems that the "compressed folder" must be created first before the compressed folder tool can be used. However, when I try to follow the instructions, I find that there is now compressed (zipped) folder option on the New menu.Maybe that functionality had been removed with the installation of WinZip (similar as the Windows defragmenter disappears with the installation of Diskeeper) ? Quote Link to comment Share on other sites More sharing options...
andsome Posted November 7, 2005 Report Share Posted November 7, 2005 You could well be right. I have NEVER installed any zip facilities in XP. The Windows zip facility has always been there. Regarding defragging. Since installing Diskeeper 7 some time ago, the Windows defrag now does NOT appear. If you uninstall Winzip, does the Windows zip facility reappear? The Windows defrag facility DOES reappear if you uninstall Diskeeper. Quote Link to comment Share on other sites More sharing options...
-pops- Posted November 7, 2005 Report Share Posted November 7, 2005 Since installing Diskeeper 7 some time ago, the Windows defrag now does NOT appear.I have Diskeeper and I also have the facility to use Windows Defragmenter if I wanted to - it's still listed under Accessories, System Tools in the Start, All Programs menu Quote Link to comment Share on other sites More sharing options...
andsome Posted November 7, 2005 Report Share Posted November 7, 2005 Since installing Diskeeper 7 some time ago, the Windows defrag now does NOT appear.I have Diskeeper and I also have the facility to use Windows Defragmenter if I wanted to - it's still listed under Accessories, System Tools in the Start, All Programs menuIf I follow your route and defrag. The resultant window says that DISKEEPER has defragged the computer. No mention is made of Windows defrag Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted November 7, 2005 Author Report Share Posted November 7, 2005 You could well be right. I have NEVER installed any zip facilities in XP. The Windows zip facility has always been there. Regarding defragging. Since installing Diskeeper 7 some time ago, the Windows defrag now does NOT appear. If you uninstall Winzip, does the Windows zip facility reappear? The Windows defrag facility DOES reappear if you uninstall Diskeeper.Uninstalled WinZip, rebooted WIndows, but the Windows zip facility did not appear. ZIP files do not even show the zip icon.Well, never mind this, I reinstalled WinZip, and I am very happy to use it when I need to zip up some files. Thanks for all the tips anyway.I have Diskeeper and I also have the facility to use Windows Defragmenter if I wanted to - it's still listed under Accessories, System Tools in the Start, All Programs menuYou must have a different version (maybe lite?); I use DK9, and it replaces the Windows defragger. I have no way of invoking the standard system defragger. Quote Link to comment Share on other sites More sharing options...
