jakenoble Posted March 8, 2006 Report Share Posted March 8, 2006 Hi all.My first post for this forum . . I have a friend that I am trying to send a .jar file to, but he does not know ifhe has JAva installed or not, so I wanted him to use Run > CMD then do java -version to display version, but he says that the CMD window just appears then disappears straight away.Why does this happen?And is there another way of getting to the CMD window?ThanksJake Quote Link to comment Share on other sites More sharing options...
r4may Posted March 8, 2006 Report Share Posted March 8, 2006 in XP Click on :- .Start -> . .Programs -> . .Command promptOr go to :- http://java.sun.com/ and click on "Get Java" Software Button Now Available" to download /check if you have the latest version. Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted March 8, 2006 Report Share Posted March 8, 2006 Try this, Start/Run then type,cmd /K consoleapp.exe Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted March 8, 2006 Report Share Posted March 8, 2006 start > run > cmdjava -versionORhttp://www.javatester.org/version.html Quote Link to comment Share on other sites More sharing options...
andsome Posted March 9, 2006 Report Share Posted March 9, 2006 This is simple quick and easy, even a blonde could do it.Click here. Quote Link to comment Share on other sites More sharing options...
VistaForums Posted March 11, 2006 Report Share Posted March 11, 2006 Im not too sure but mine would do that when I wasnt running it as an administrator. Quote Link to comment Share on other sites More sharing options...
r4may Posted March 11, 2006 Report Share Posted March 11, 2006 This is simple quick and easy, even a blonde could do it.Click here.All I got was :- Quote Link to comment Share on other sites More sharing options...
andsome Posted March 12, 2006 Report Share Posted March 12, 2006 This is what you should see. Quote Link to comment Share on other sites More sharing options...
