casey Posted April 7, 2006 Report Share Posted April 7, 2006 Just built a computer but when I try to install XP it goes through the loading files stage, then when it comes to start windows it comes up with a stop error 0x0000007b saying check for viruses and check disk configuration.This happens with either Sata or Ide hard disks.I looked up the error number & it said might be memory so tried one stick at a time. Still the same.I did manage to get ME to run using a H/disk with it already installed on using a boot loader, so cannot be much wrong.Any ideas gratefully received.Asus P5WD2 mother board.Intel 4 dual core processor.Nvidea 6600 graphics2 * 512 crucial ram200 g Sata hard disk Quote Link to comment Share on other sites More sharing options...
Boris Posted April 7, 2006 Report Share Posted April 7, 2006 Have you looked here ?http://support.microsoft.com/default.aspx?...kb;en-us;324103 Quote Link to comment Share on other sites More sharing options...
casey Posted April 8, 2006 Author Report Share Posted April 8, 2006 Thanks. Had seen this in my search but don't understand all of it.I will probably have a go at updating the bios. Never tried this before but it does say in my handbook I can recover from a failed update, so hopefully I am safe.I have found a lot of queries over this fault but no real answer. Ken Quote Link to comment Share on other sites More sharing options...
casey Posted April 9, 2006 Author Report Share Posted April 9, 2006 Have now updated to the latest bios but still doesn't load.Ken Quote Link to comment Share on other sites More sharing options...
-pops- Posted April 9, 2006 Report Share Posted April 9, 2006 Is the RAM the brand suggested/recommended by ASUS?The reason I ask is because a machine I built with an ASUS A7N8X-E had ASUS Samsung memory recommended. I ignored that, put in Crucial (ostensibly the same) and the machine wouldn't load. Swapped for Samsung and it worked OK. Quote Link to comment Share on other sites More sharing options...
casey Posted April 10, 2006 Author Report Share Posted April 10, 2006 Thanks for that suggestion, I AM using Crucial memory (dual 512m) and have tried swopping them around different slots with no luck so perhaps yours is the answer. The only problem is I purchased them from Crucial so can't get them exchanged for a different make.Ken . Quote Link to comment Share on other sites More sharing options...
casey Posted April 13, 2006 Author Report Share Posted April 13, 2006 All working now. Changed DVD rom into a different socket got over that problem & a bit of meddling in the bios got over the rest of the problem(Cannot find HD). Quote Link to comment Share on other sites More sharing options...
