RenoSaurus Posted July 6, 2006 Author Report Share Posted July 6, 2006 There have been a couple posts lost in the down time.You can reorder the processes by clicking on the cpu tab when in the page, lowest or highest usage at the top.Looking at your screenshot we are unable to see perhaps 50% of your running processes, have you tried scrolling down using the scroll bar ?yes. I've pushed the cpu button reguarly. also, I've pushed the PID button, sorting the highest value on top. but neither the cpu tab or the PID tab shows why my CPU is pushing 50% Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted July 7, 2006 Report Share Posted July 7, 2006 I don't understand why you absolutely won't tell us which of the processes is using the 50% CPU. Nobody here can see your Task Manager, except you. And the one screenshot you provided had the 50% task hidden in the scroll area. Quote Link to comment Share on other sites More sharing options...
RenoSaurus Posted July 7, 2006 Author Report Share Posted July 7, 2006 I don't understand why you absolutely won't tell us which of the processes is using the 50% CPU. Nobody here can see your Task Manager, except you. And the one screenshot you provided had the 50% task hidden in the scroll area.you don't understand right? well, neither do I. wanna know why I won't tell it? because there's nothing to tell.I've said it a couple of times, but I might not have been clear enough. I don't live in a country where English is the native language so. I'll try to explain myself again:There is no proces in my task manager that uses 50% of my cpu. None. ALL the values are the same as when my pc runs normally.That's the strange thing. Quote Link to comment Share on other sites More sharing options...
mark2 Posted July 8, 2006 Report Share Posted July 8, 2006 When you push the cpu button which process is at the top of the list?Generally "system idle process" will be the highest user, and thus likely will be at the top when you've cycled the cpu button to reorder your processes to show the highest usage.other than that we can only see 16 of the 51 processes running in your screenshot, and as you don't see anything using 50% , a post in the Hijackthis and security forum is probably the way to go. Quote Link to comment Share on other sites More sharing options...
RenoSaurus Posted July 8, 2006 Author Report Share Posted July 8, 2006 When you push the cpu button which process is at the top of the list?Generally "system idle process" will be the highest user, and thus likely will be at the top when you've cycled the cpu button to reorder your processes to show the highest usage.other than that we can only see 16 of the 51 processes running in your screenshot, and as you don't see anything using 50% , a post in the Hijackthis and security forum is probably the way to go.OK, though I think my pc is safe. I've resently been cleaning it, cause I had a virus named backdoor. So then I secured my pc again. I'll post, but what do I say? Quote Link to comment Share on other sites More sharing options...
Boris Posted July 8, 2006 Report Share Posted July 8, 2006 Post a HijackThis LogInstructions here :-http://forums.windowsforum.org/index.php?showtopic=6901 Quote Link to comment Share on other sites More sharing options...
