Alan2273 Posted June 23, 2006 Report Share Posted June 23, 2006 I downloaded Autoruns and did as suggested, then rebooted the computer to see what happened.Now when I go to switch user (there are only 2 accounts mine and the wifes) I get a box that is titled UNLOCK COMPUTER.In the box it says THIS COMPUTER IS IN USE AND HAS BEEN LOCKED, ONLY ********** OR AN ADMINISTRATOR CAN UNLOCK THIS COMPUTER, then it has my name in the user box and asks for a password.I have never set a password on this computer so I pressed enter and the box just came back.So the wife is a very annoyed as she cannot access her account.How do I unlock the computer, I have tried a system restore and no difference. Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted June 23, 2006 Author Report Share Posted June 23, 2006 I downloaded Autoruns and did as suggested, then rebooted the computer to see what happened.Now when I go to switch user (there are only 2 accounts mine and the wifes) I get a box that is titled UNLOCK COMPUTER.In the box it says THIS COMPUTER IS IN USE AND HAS BEEN LOCKED, ONLY ********** OR AN ADMINISTRATOR CAN UNLOCK THIS COMPUTER, then it has my name in the user box and asks for a password.I have never set a password on this computer so I pressed enter and the box just came back.So the wife is a very annoyed as she cannot access her account.How do I unlock the computer, I have tried a system restore and no difference.Just an aside I have been able to access the wifes account by typing her name in the UNLOCK COMPUTER box,But I would appreciate getting the welcome screen back. Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted June 23, 2006 Report Share Posted June 23, 2006 Go to your screen saver, under display properties, and turn off: "On Resume, Display Welcome Screen"You may also want to go into the Power > Advanced section, and uncheck ask for a password when resuming from standby. Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted June 23, 2006 Author Report Share Posted June 23, 2006 Go to your screen saver, under display properties, and turn off: "On Resume, Display Welcome Screen"You may also want to go into the Power > Advanced section, and uncheck ask for a password when resuming from standby.SM, I do not use a screen saver, so I put one on but did still not get the ON RESUME option.Also in the Power>Advanced it was not ticked for a password. Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted June 23, 2006 Author Report Share Posted June 23, 2006 All solved, edited the registry, put the tick back in the WGA box and had to put updates back to automatic.And thanks to Nell for this which pushed me in the right direction.Sheeshe.. I do apologise, this workaround is causing more trouble than it seems to be worth... you could try running autoruns and putting the tick back in the WgaLogon box. Or... it might just be bad timing, I found this http://support.microsoft.com/?kbid=242917 Quote Link to comment Share on other sites More sharing options...
nellie2 Posted June 23, 2006 Report Share Posted June 23, 2006 Quote Link to comment Share on other sites More sharing options...
