CJ550 Posted August 21, 2006 Report Share Posted August 21, 2006 When i try and play a DVD in Media Plyer i get this message--"Windows Media Player cannot play the DVD because a compatible DVD decoder is not installed on your computer"is this DVD software i need to purchase or can i get it somewhere free? I have a nvidia 6600 card would a DVD coder have come with it? thanks Quote Link to comment Share on other sites More sharing options...
Belatucadrus Posted August 21, 2006 Report Share Posted August 21, 2006 AVS DVD player is free and incorporates its own Codec, so works out of the box. Comes with a limited trial version their commercial Video tools, but it's easy to uninstall without harming the player.Or you could add K-lite and get your existing media players to work with DVD. Quote Link to comment Share on other sites More sharing options...
-pops- Posted August 21, 2006 Report Share Posted August 21, 2006 I would thoroughly recommend the klite pack as suggested by Belatucadrus. It has just about every codec you could ever want.I get it from http://www.free-codecs.com/download/K_Lite_Codec_Pack.htm Quote Link to comment Share on other sites More sharing options...
CJ550 Posted August 22, 2006 Author Report Share Posted August 22, 2006 thanks Quote Link to comment Share on other sites More sharing options...
