digler Posted November 3, 2006 Report Share Posted November 3, 2006 Hi,I have XP Pro installed on my laptop that is not a legit gopy but have XP home key sticker on the bottom which I intend to use.Is there a way I can re install XP Home over XP Pro and keep the settings or do I have to wipe everything off and start again? Or is there a way i could back up files etc?Any help would be greatly appreciated.Scott Quote Link to comment Share on other sites More sharing options...
digler Posted November 3, 2006 Author Report Share Posted November 3, 2006 Does anyone know of a good guide to install windows XP to save me from messing up my laptop ThanksScott Quote Link to comment Share on other sites More sharing options...
andsome Posted November 3, 2006 Report Share Posted November 3, 2006 You have come to the right place. Click here Quote Link to comment Share on other sites More sharing options...
nellie2 Posted November 3, 2006 Report Share Posted November 3, 2006 You can't install XP Home over XP Pro, it would have to be a clean install. The way I would do it would be to put all my documents, favourites, programs and email settings etc onto a CD or DVD before I wiped the machine Quote Link to comment Share on other sites More sharing options...
digler Posted November 6, 2006 Author Report Share Posted November 6, 2006 Hi,Thank you both for your help. Everything seems to be working fine and I am now able to get all of the microsoft updates.One thing i did notice was when XP was being copied it strugled on a couple of files and asked if I wanted to retry, which worked, but the file driver.cab would not work and I continued anyway. Like I said everything seems OK but I wondered what that file is for and if it would effect anything. Does anyone know?ThanksScott Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted November 6, 2006 Report Share Posted November 6, 2006 http://en.wikipedia.org/wiki/Cabinet_(file_format) Quote Link to comment Share on other sites More sharing options...
digler Posted November 6, 2006 Author Report Share Posted November 6, 2006 Thanks for the info. But what does the file "driver.cab" contain or what is it used for? Should I try and re-install or can I add this file manually? Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted November 7, 2006 Report Share Posted November 7, 2006 Most likely it contains device driver installation files. Check if all your device drivers are correctly installed (Device Manager, from Control Panel | System | tab Hardware | Device Manager). If yes, then I wouldn't worry too much. Quote Link to comment Share on other sites More sharing options...
