Sind Posted January 3, 2007 Report Share Posted January 3, 2007 Whenever I try to play a game in full screen a grey box appears in the middle of the screen saying:For best picture quality, please change resolution to 1280x1024.SELECT:Disable EXIT:ClearThe resolution is already 1280x1024 and I can't make the box go away. It won't let me do anything to it. Does someone know what to do with it?Thanks in advance. Quote Link to comment Share on other sites More sharing options...
nellie2 Posted January 3, 2007 Report Share Posted January 3, 2007 This might have something to do with your monitor settings, have a look in your monitor's set up and see if you can find an option that will disable this Quote Link to comment Share on other sites More sharing options...
Sind Posted January 4, 2007 Author Report Share Posted January 4, 2007 I have tried changing every possible monitor setting but it still stays there. The computer was formated once but the box appeared before formating and after it. Quote Link to comment Share on other sites More sharing options...
-pops- Posted January 4, 2007 Report Share Posted January 4, 2007 Have you made enquiries with the makers of the game?One thing I've thought - try changing the screen resolution to a lower level, test the game and them put it back to the one the game requests. Quote Link to comment Share on other sites More sharing options...
Sind Posted January 4, 2007 Author Report Share Posted January 4, 2007 It does that with every game I have.Already tried changing it that way. Doesn't work. Quote Link to comment Share on other sites More sharing options...
babysun Posted January 4, 2007 Report Share Posted January 4, 2007 What kind of games are you trying? If we can know... what graphic card/software have you installed?Just saw it's nvidia, have you tried settings in nvidia...? [try setting it to default] Quote Link to comment Share on other sites More sharing options...
Sind Posted January 4, 2007 Author Report Share Posted January 4, 2007 It doesn't matter what game it is as long as it's full screen. The box disappeared in Stepmania only when I set the game to be windowed. But the other games' options won't let me do that. Currently I'm trying to play Lionheart: Legacy of the Crusader which I just bought.I tried the default setting but it didn't work. Quote Link to comment Share on other sites More sharing options...
nellie2 Posted January 4, 2007 Report Share Posted January 4, 2007 what is the make of your monitor and what is the make of your graphics card Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted January 5, 2007 Report Share Posted January 5, 2007 what is the make of your monitor and what is the make of your graphics cardAnd what driver & version you have installed? Quote Link to comment Share on other sites More sharing options...
