page Posted February 12, 2007 Report Share Posted February 12, 2007 Today I decide to defrag my C drive again, but still not working. I've attached my two images show before and after defrag, I even save the defrag report for reference.Pls help.tks Quote Link to comment Share on other sites More sharing options...
-pops- Posted February 12, 2007 Report Share Posted February 12, 2007 You could try using an independent utility like Diskeeper Lite click here. Several forum members use it and are happy with it. Quote Link to comment Share on other sites More sharing options...
doug Posted February 12, 2007 Report Share Posted February 12, 2007 I use DK lite version (free) and am very happy with it. It runs a bit faster than the M$ version as well. Quote Link to comment Share on other sites More sharing options...
dadyassa Posted February 12, 2007 Report Share Posted February 12, 2007 I use it also and find it very good.One advantage is, you dont have to shut anything down to get it to run. ;) Quote Link to comment Share on other sites More sharing options...
jason.b.c Posted February 12, 2007 Report Share Posted February 12, 2007 Try Power DefragmenterMan , I'm glad i don't need to worry about defraging anymore... Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted February 13, 2007 Report Share Posted February 13, 2007 I agree that Diskeeper Lite is the best alternative to the Windows built-in defragmenter (also developed by Executive Software). The generally available version of DKL is 7; however you can download DK Lite version 9 from http://www.intel.com/design/motherbd/software/idu/ (as part of the Intel® Desktop Utilities version 2.1.9.66). Quote Link to comment Share on other sites More sharing options...
doug Posted February 13, 2007 Report Share Posted February 13, 2007 I'm running DK7 Pat on an AMD m/c. Any advantage in me going for the 9 version, considering that what I'm running isn't bust? Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted February 13, 2007 Report Share Posted February 13, 2007 Good question! I just had a little reading of the README file for DK9 Lite; it saysThis edition of Diskeeper is supported on on Intel x86 platforms (or compatible) running Windows 2000 Professional or Windows XP.Now I don't know if AMD is x86 compatible...?I do not know if there are any or what changes since DK7 Lite, but if you know me, you know that I always go for the newest software. Quote Link to comment Share on other sites More sharing options...
doug Posted February 13, 2007 Report Share Posted February 13, 2007 Might give it a go then. Quote Link to comment Share on other sites More sharing options...
doug Posted February 13, 2007 Report Share Posted February 13, 2007 Just came across this, might postpone any hasty action for the mo. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted February 13, 2007 Report Share Posted February 13, 2007 Once you have unpacked the file, you can find Diskeeper under the 3rdparty folder. Quote Link to comment Share on other sites More sharing options...
doug Posted February 13, 2007 Report Share Posted February 13, 2007 Huh? talk me through that again. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted February 13, 2007 Report Share Posted February 13, 2007 Sorry, I have been away for a while...You download the Intel Desktop Utilities v2.1.9.66 (IDU_2.1.9.66.exe) from the download link above. When you run that executable, it will just extract a series of directories and subdirectories with various installers; you probably point the result somewhere like "C:\My Download Files\Intel" or such.It will create a directory 'IDU_2.1.9.66' with subdirectories '3rdparty', 'awinstaller', 'drivers', 'smbios', and 'smbus'. '3rdparty' contains the 'Diskeeper' subdirectory with the DK9 Lite installer. Don't use the 'Diskeeper.64' directory; I guess it contains the 64bit installer.Most other tools in that download are Intel-specific tools, so just delete them after the extract.Let me know how it goes with DK9 Lite - better than 7...?P.S. it contains a nag pop-up to buy the full product; I hope that this is not too annoying for you. Quote Link to comment Share on other sites More sharing options...
dadyassa Posted February 13, 2007 Report Share Posted February 13, 2007 Sorry, I have been away for a while...You download the Intel Desktop Utilities v2.1.9.66 (IDU_2.1.9.66.exe) from the download link above. When you run that executable, it will just extract a series of directories and subdirectories with various installers; you probably point the result somewhere like "C:\My Download Files\Intel" or such.It will create a directory 'IDU_2.1.9.66' with subdirectories '3rdparty', 'awinstaller', 'drivers', 'smbios', and 'smbus'. '3rdparty' contains the 'Diskeeper' subdirectory with the DK9 Lite installer. Don't use the 'Diskeeper.64' directory; I guess it contains the 64bit installer.Most other tools in that download are Intel-specific tools, so just delete them after the extract.Let me know how it goes with DK9 Lite - better than 7...?P.S. it contains a nag pop-up to buy the full product; I hope that this is not too annoying for you.You get the popup with the other version too, but only when it needs doing. ;) Quote Link to comment Share on other sites More sharing options...
page Posted February 14, 2007 Author Report Share Posted February 14, 2007 I agree that Diskeeper Lite is the best alternative to the Windows built-in defragmenter (also developed by Executive Software). The generally available version of DKL is 7; however you can download DK Lite version 9 from http://www.intel.com/design/motherbd/software/idu/ (as part of the Intel® Desktop Utilities version 2.1.9.66).Hi,Is it for intel centrino Laptop? Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted February 15, 2007 Report Share Posted February 15, 2007 Hi,Is it for intel centrino Laptop?Sure, no problem. Actually I do not think that it is even limited to Intel; I think it should run under any Windows system. Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted February 15, 2007 Report Share Posted February 15, 2007 Now I don't know if AMD is x86 compatible...?AMD is x86. Intel just 'invented' it first. Quote Link to comment Share on other sites More sharing options...
y2khardtop Posted February 16, 2007 Report Share Posted February 16, 2007 I use DK9 (full version) and it works great. However, why isn't windows version working. I would try deleting your paging file, and running it in SAFE mode.Might be time to do a clean install of windows as well Quote Link to comment Share on other sites More sharing options...
