ISO Help
Requiem
You seem to be burning the file to the disc,
try
Start Nero, cancel the wizard. Now click on Recorder>Burn image.
When the next box open, select all files from the drop down box, navigate your way to the folder with the ISO in and select it.
At the next screen click on ok (do not modify)
On the last screen prior to burning ensure that you click on "Finalize Cd" box and select your burn rate.
Thats it NERO will now burn your ISO/IMAGE files
just to clearify it a bit for you :-)
An ISO is a direct image of a media, usually CD or DVD.
It is somewhat made from bit to bit reading the media, and storing it in a file.
The file then gets some meta data, like creator and like.
If you burn the ISO file on to a media, you will get a data media, containing the ISO file, as it was on your harddrive.
But if you wanna burn the image, stored within the ISO file, you need to specially select "burn image" and then select the ISO and burn it.
This leaves no questions about how to burn it (data, sound or mixed mode f.x.) since the burn mode and data all is stored in the ISO.
Nero has an option to burn ISO images, but there is also dedicated programs, that can easily burn images, just look at the previous posts :-)
hope you got the info you where looking for...
