Coreper Posted April 13, 2007 Report Share Posted April 13, 2007 hi, ive got a few [very?] complicated questions for you guys, but before telling it, i will tell my story:ive got 2 GB of RAM [twice 512 and once 1 GB], a Dual Core Processor [2x 2.2 Ghz] {AMD}, two 256 MB 7600 nVidia videocards.lets say i would connect another monitor [on the other videocard], mouse and keyboard,then i would use a desktop manager to display a different desktop at both monitorsnow here are my questions:1. would it be possible that i could use both desktops at the same time [using the 2 monitors, keyboards and mouses]?2. if yes, would it be possible to "fake" a LAN/network connection and use the two desktops to play a game together?i have been wanting to know this for a very long time, so just let me know if your interested or if you have any piece of help [even the very small bits are helpfull!]btw:to get multiple desktops, you should use a desktop managerfor example: Windows Desktop Manager > but this one only allows you to use 1 at the time... Quote Link to comment Share on other sites More sharing options...
nellie2 Posted April 13, 2007 Report Share Posted April 13, 2007 I can't give you a difinitive answer but logic tells me that this wouldn't be possible as you only have one operating system and one registry,.. however you should be able to run Virtual PC;s quite happily so you could network the VPC with your main system and do it like that........... I think. Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted April 13, 2007 Report Share Posted April 13, 2007 Nel's right. A virtual PC is the only way to do this.You can get a KVM (Keyboard, Video, Mouse) switch and have 1 computer be able to be used by multiple people, but not at the same time, and not with seperate desktops and network interfaces. Quote Link to comment Share on other sites More sharing options...
Coreper Posted April 16, 2007 Author Report Share Posted April 16, 2007 too bad...would have been really cool if it could have been... [heavy duty for the pc though...]thanks for the replies Quote Link to comment Share on other sites More sharing options...
