Need Help > internet P2p applications
NIRi
Hey all..
This issue is regarding the Internet connectivity...
Everything works fine in the computer, I can browse,download files using web browsers ( Ex : IE 6, IE 7, Mozilla Firefox, Netscape )
There is no problem with the web browsers, but when it comes to P2P applications like Ares, Azureus, BitLord, Limewire, E-Donkey..... am not able to connect to their respective servers, in short these applications doesn't connect to internet.
I've tried changed the port settings within these applications, disabled firewall, ran an online windows live one care scan (safety.live.com).. even after that there is no change..
And i've noticed one funny thing thats whenever i try
"ping www.yahoo.com", for that matter whenever i ping any website its gives out a message saying "ping request timed out"
i've tried resetting winsock, tcp/ip. ipconfig /release, ipconfig /renew. No security applications, windows firewall disabled.
and i also have a computer where in i have windows vista installed, but everything works fine that the vista computer.
Am running XP PRO SP2 with 512 RAM, DSL connection connected via router ( wired connection )
well i'll be looking forward for the valuable suggestions... and please don't suggest to reinstall the whole operating system, which i cannot do, as its a very tedious process when it comes to windows.
Regards
- Niranjan Rolling Eyes
I think that MOST of the members would recommend that if you don't want to take risks with your computer, AVOID p2p like the plague.
Avoiding P2P is bit difficult..
But apart from that any other suggestions...??
We need it real bad !!! :huh:
As your computer is connected using a router have you checked to see if it has a firewall as my router does.
Well i've checked for the router settings, it works in vista computer, but not in XP PRO... guess there is some problem with XP not with the router settings..
