Malkav Posted August 29, 2007 Report Share Posted August 29, 2007 Hi everybody :)I am having Issues with my audio in XP. To put it simply its choppy, really choppy and its choppy even though its on a fresh install of XP and theres no program running with it. Now I am sure that its not a hardware related issue because I run Linux on the same computer(Dual-Boot) and it lets me play audio+play Doom3 at the same time without any issues. Its probably not the players fault aswell since I've attempted two, Winamp and Windows Media Player.So it seems to come down to the OS or driver's fault, I've already tried updating the driver and it didnt changed a thing. I dont believe its a Virus or spyware since I am running daily checks against them and I always come out clean. And thats the part I am stuck at. I have zero idea on what to do now. I am running a Realtek HD, and I am running a fully updated version of XP SP2. Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted August 29, 2007 Report Share Posted August 29, 2007 Microsoft suggests drivers.http://support.microsoft.com/kb/192046/Make sure you have installed the most recent drivers, and try a Codec pack like K-Lite Codec Pack Quote Link to comment Share on other sites More sharing options...
Malkav Posted August 29, 2007 Author Report Share Posted August 29, 2007 err sorry to say but first of all the test you gave me applies only to:• Microsoft Windows 98 Standard Edition• Microsoft Windows Millennium Editionor so its written.Second, I already said:I've already tried updating the driver and it didnt changed a thing.About the Codecs I have XP Codec Pack instead of K-Lite... it should do the trick since I've used it in the past, but not on this computer directly. Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted August 29, 2007 Report Share Posted August 29, 2007 You are correct. I apologize I did not read the systems that article applied to. Give the codec pack a try and let us know how it goes. Quote Link to comment Share on other sites More sharing options...
Malkav Posted August 29, 2007 Author Report Share Posted August 29, 2007 no problem :) wont it conflict with the XP-Codec pack?nope, still has the same issue...btw, I liked the links in your sig... but what does "Ancora Imparo" means? Quote Link to comment Share on other sites More sharing options...
CurlyWhirly Posted August 30, 2007 Report Share Posted August 30, 2007 but what does "Ancora Imparo" means?http://www.ancoraimparo.net/index.php?opti...2&Itemid=51So, you have come in search of the answer to the question, "What is Ancora Imparo"? Well, this is where you will find your answer. What does it mean? The motto Ancora Imparo is attributed to Michelangelo and means 'I am still learning'. or "Still, I am learning". Quote Link to comment Share on other sites More sharing options...
Malkav Posted September 1, 2007 Author Report Share Posted September 1, 2007 ok, thanks for the info... But I still need help with the audio. Quote Link to comment Share on other sites More sharing options...
Malkav Posted September 2, 2007 Author Report Share Posted September 2, 2007 err help? Anyone? please? Quote Link to comment Share on other sites More sharing options...
Mike567 Posted September 2, 2007 Report Share Posted September 2, 2007 reinstall the drivers system information >> device manager and look for the soundcard in their right click it uninstall then reboot the computer which then windows xp should auto detect it and reinstall the drivers. Quote Link to comment Share on other sites More sharing options...
Malkav Posted September 3, 2007 Author Report Share Posted September 3, 2007 I did it and the drivers auto-reinstall themselves immidiatly after bootup. but the whole audio is still choppy. so seems like driver re installment didn't helped. Any other ideas? Quote Link to comment Share on other sites More sharing options...
Mike567 Posted September 3, 2007 Report Share Posted September 3, 2007 I think microsoft are telling you to use linux ;), I cant think of any other ideas though. Quote Link to comment Share on other sites More sharing options...
Boris Posted September 3, 2007 Report Share Posted September 3, 2007 Is it a dedicated PCI Sound Card or onboard sound? Quote Link to comment Share on other sites More sharing options...
Malkav Posted September 4, 2007 Author Report Share Posted September 4, 2007 its the onboard card that came with my MB: GA-945GZM-S2so from what I understood I got a Realtek audio (Realtek ALC888 audio codec chipset. and a Realtek HD Driver) however I could be wrong about it since My computer also has an Intel 945GZ Chipset, which my also include audio.Furthermore this is official a 6.1 audio device, however I got a stereo connected to it and from what I understood by the book the jumpers on the MB define if its stereo or 6.1. and the place where I bought the audio said that they configured the audio for stereo. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted September 5, 2007 Report Share Posted September 5, 2007 It could be something else that is interfering with the sound. Watch the Task Manager (Processes) if anything else is taking CPU or memory away from the application that is playing the sound(s). Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted September 5, 2007 Report Share Posted September 5, 2007 btw, I liked the links in your sig... but what does "Ancora Imparo" means?I am still learning B) Press ctrl+alt+del and go to the performance tab. What % of CPU Usage is being used? Quote Link to comment Share on other sites More sharing options...
Malkav Posted September 6, 2007 Author Report Share Posted September 6, 2007 CPU wise its jumping from 1% to 9% (but its most of the time staying around 4%) now from what I've seen in the two graphs I see that the first one about twice as big as the second one... but they're both fairly low. and memory wise. everything is normal. no one of the apps is taking too much memory, except Firefox which takes ~83,500 but I believe its normal due all of my addons.And eitherway the choppy audio happens even without FF running. From what I've noticed the audio is equally choppy even with Firefox working, hell even with a game running its still equally choppy... nothing I do even remotlely effects the choppy audio. (from the few I tested atleast) Quote Link to comment Share on other sites More sharing options...
Malkav Posted September 9, 2007 Author Report Share Posted September 9, 2007 help plz Quote Link to comment Share on other sites More sharing options...
Malkav Posted September 22, 2007 Author Report Share Posted September 22, 2007 Err, guys I'm still having those issues and its only getting worse :/ I really need some help here Quote Link to comment Share on other sites More sharing options...
