Panarchy Posted September 27, 2007 Report Share Posted September 27, 2007 Hello to all!Just today I bought myself a brand new 400GB hard-drive. :PI want to partion it (I think partion is the right word) so that I can have;Windows XPSolarisLinuxOn my other harddrive I have Vista, so I want to be able to view files from all these OS's installations.Please tell me how I can do this, I don't mind buying a program if it is worthwhile.Thanks in advanced,Panarchy Quote Link to comment Share on other sites More sharing options...
-pops- Posted September 27, 2007 Report Share Posted September 27, 2007 You've missed a bit out of the word, Panarchy. - it is partition and if you look in Windows Help & Support you will see how to do it from within Windows. It's very easy to do, provided you do it correctly! :) Quote Link to comment Share on other sites More sharing options...
Panarchy Posted September 27, 2007 Author Report Share Posted September 27, 2007 Ah! I knew it didn't sound right! Partition!So I don't need to use Partition Magic or anything like that? Quote Link to comment Share on other sites More sharing options...
-pops- Posted September 27, 2007 Report Share Posted September 27, 2007 Not if it's a new drive.You only need specialist partitioning software if you want to partition a drive and retain data or something special like that. Quote Link to comment Share on other sites More sharing options...
Panarchy Posted September 27, 2007 Author Report Share Posted September 27, 2007 Oh! Okay then!Thanks a heap!What CD (OS CD/bootdisc) should I insert and format with first? Quote Link to comment Share on other sites More sharing options...
-pops- Posted September 27, 2007 Report Share Posted September 27, 2007 Ah! you've got me there.I've only partitioned drives in Windows so you'll have to get a reply from an expert in the other systems to answer that one for you. I'm sure there's someone here who will help. Quote Link to comment Share on other sites More sharing options...
Panarchy Posted September 27, 2007 Author Report Share Posted September 27, 2007 Okay!Thanks!I think I will install Solaris first... Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted September 27, 2007 Report Share Posted September 27, 2007 http://multiboot.solaris-x86.org/ Quote Link to comment Share on other sites More sharing options...
