Amara Posted December 18, 2007 Report Share Posted December 18, 2007 I am running windows XP home on a Dell Inspiron B120 laptop and I am having troubles with my Sandisk USB flash drive. I was able to use my flash drive without problems for a few months, but last week I ran into a problem. I went to open my flash drive from my computer and it said that it was not working properly and asked if I wanted to reformat it. I said yes, but it wouldn't do it because it said the drive was write protected. I know that most flash drives have a write protection switch, but I do not see any way that I could have flipped it accidentally because I think it is inside the casing. I checked the status of the drive in device manager and it says it is working properly, but it is clearly not. I then tried to go into disk manager from administrative tools to try and repartition it thus overwriting the write protection, but that option was greyed out when I right clicked it. I've also looked into some free software for reformatting and re-partioning, but so far nothing has been able to get past the write protection issue.My question is, does anyone know where specifically the write protection tab might be? (unfortunately I don't know the model of my drive, only that it is Sandisk) Also, is there a way to get around the write protection issue to reformat and make it usable again either with software(preferably free) or some other way? Any suggestions will be greatly appreciated.Thanks. Quote Link to comment Share on other sites More sharing options...
-pops- Posted December 18, 2007 Report Share Posted December 18, 2007 This is very much like a hot plugging problem which I wrote about here: http://forums.windowsforum.org/index.php?showtopic=32464 Quote Link to comment Share on other sites More sharing options...
Amara Posted December 18, 2007 Author Report Share Posted December 18, 2007 This is very much like a hot plugging problem which I wrote about here: http://forums.windowsforum.org/index.php?showtopic=32464Thanks for the link. I don't think that is my problem, but it is always possible. I always use the safely remove hardware button when removing it except for every once in a while when I need to get it out when my computer is hibernating and I don't feel like starting it up just to remove it. I always assumed that if it was in hibernate unpluging it then wouldn't be a problem because it has already for the most part powered down and finished all processes. Is this right?Any other suggestions to solve the problem? Quote Link to comment Share on other sites More sharing options...
casey Posted December 18, 2007 Report Share Posted December 18, 2007 If I go to the icon and select USB then properties then policies it gives the choice of optimising for quick removal (for removal wihout using Safe Removal) or optimising for performance(using Safe removal) Quote Link to comment Share on other sites More sharing options...
Amara Posted January 12, 2008 Author Report Share Posted January 12, 2008 Are there anymore suggestions to my problem? Any help you can offer is great. Quote Link to comment Share on other sites More sharing options...
Irene Posted January 12, 2008 Report Share Posted January 12, 2008 Hello, Amara!I wondered if this might help....LOOK HERE Quote Link to comment Share on other sites More sharing options...
Amara Posted January 13, 2008 Author Report Share Posted January 13, 2008 Hello, Amara!I wondered if this might help....LOOK HEREThat seems like it should work, but when I went into properties of my drive there was no sharing tab. Thanks anyway for t he link though. Quote Link to comment Share on other sites More sharing options...
