olemand Posted January 22, 2008 Report Share Posted January 22, 2008 Hey I was so unfortunate to press wrong button when i wanted to empty recycle bin, I pressed delete and enter. Now it's gone, I don't know how to get it back so I can empty ??? Can any of you help me ?? =P Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted January 22, 2008 Report Share Posted January 22, 2008 http://support.microsoft.com/kb/810869 Quote Link to comment Share on other sites More sharing options...
Boris Posted January 22, 2008 Report Share Posted January 22, 2008 This is just a bit simpler ?Download this fix from Kelly's Korner and then double click it to amend your registry :)http://www.kellys-korner-xp.com/regs_edits...erecyclebin.reg Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted January 23, 2008 Report Share Posted January 23, 2008 Or even more simple (with lots of additional stuff):Download TweakUI from the Microsoft PowerToys page and install it. You can add or remove any of the system desktop items you want. Quote Link to comment Share on other sites More sharing options...
windowsfirst Posted January 23, 2008 Report Share Posted January 23, 2008 I would suggest TweakUI from Microsoft that is very good tools------------------------------------------------------------------------Windows Referencehttp://www.windowsreference.com Quote Link to comment Share on other sites More sharing options...
Coreper Posted January 24, 2008 Report Share Posted January 24, 2008 are you sure he deleted his recycle bin icon, or did he delete the contents?it sounds to me like he accidentally deleted the contents...i could be wrong though... Quote Link to comment Share on other sites More sharing options...
olemand Posted January 24, 2008 Author Report Share Posted January 24, 2008 Thx all. I figured it out now, just had to go into display properties and restore desktop icons. =) Quote Link to comment Share on other sites More sharing options...
