MacOSXrocksToo Posted February 14, 2008 Report Share Posted February 14, 2008 Why is it that when I type CTRL+ALT+DEL, and click on the "Processes" tab, explorer.exe is using about 29,000K's of memory, but when I quit the process and restart it, it only uses about 24,000K's of memory?! Is there any way to fix this? Is it a problem? Also, svchost uses about the same as explorer.exe too.....What's up with this?Thanks! :DAlso, I am editing, I noticed that explorer actually over time (about 7 minutes) increases to about 27,000K after restarting the explorer.exe process. Quote Link to comment Share on other sites More sharing options...
-pops- Posted February 14, 2008 Report Share Posted February 14, 2008 I don't think this is a problem. Just checked two of my machines - one at 28,080 the other at 29,000.Since starting this, the first machine (this one) has risen to 29,040.Is this causing a real problem to you? If not, I suggest you forget about it. There can be huge numbers of difficulties caused by trying to sort out non-existent problems and if your machine is working satisfactorily, best to leave things alone.(It's now 28,116). Quote Link to comment Share on other sites More sharing options...
MacOSXrocksToo Posted February 14, 2008 Author Report Share Posted February 14, 2008 its not a problem, but my friends sticks around 24,000 all the time. And I don't want explorer.exe hogging most of my 512 MB memory. Also, whats the deal with svchost? How much memory does yours usually stick around?Thanks! Quote Link to comment Share on other sites More sharing options...
-pops- Posted February 14, 2008 Report Share Posted February 14, 2008 I have several instances of svchost: 20,400, 5400 and 4,388 Quote Link to comment Share on other sites More sharing options...
MacOSXrocksToo Posted February 14, 2008 Author Report Share Posted February 14, 2008 So, this isn't a problem? What could cause explorer.exe to use more memory than my friends computer? BTW, we have the same exact computer. Quote Link to comment Share on other sites More sharing options...
Boris Posted February 14, 2008 Report Share Posted February 14, 2008 So, this isn't a problem? What could cause explorer.exe to use more memory than my friends computer? BTW, we have the same exact computer.It would differ unless you run exactly the same software at the same time though ? Quote Link to comment Share on other sites More sharing options...
AlanHo Posted February 15, 2008 Report Share Posted February 15, 2008 Why is it that when I type CTRL+ALT+DEL, and click on the "Processes" tab, explorer.exe is using about 29,000K's of memory, but when I quit the process and restart it, it only uses about 24,000K's of memory?! Is there any way to fix this? Is it a problem? Also, svchost uses about the same as explorer.exe too.....What's up with this?Thanks! :DAlso, I am editing, I noticed that explorer actually over time (about 7 minutes) increases to about 27,000K after restarting the explorer.exe process.If you have cause to worry - I should be suicidal.I just opened task manager whilst this website is open in IE7. No other programmes are running in the task bar other than task manager.I have two instances of explorer.exe shown. One at 92,684K and the other at 44,256K. My RAM is showing 42% utilisation.If I close IE7, the 44,256K one vanishes and the 92,684K instance drops to 92,340K. RAM utilisation then shows at 34%. Quote Link to comment Share on other sites More sharing options...
