bubble rida Posted August 22, 2008 Report Share Posted August 22, 2008 Can someone please help me? I am trying to install windows xp into my panasonic CF-T5 Intel® Core Duo Processor Mobile Intel® 945 GMS Express chip set 512 MB, DDR2 SDRAM. I get a blue screen with the following :STOP: 0X0000007E (0XC0000005, 0XF854a0bf, 0XF8996208, 0XF8995f08)pci.sys - Address f854a0bf base at f8543000, Datestamp 3b7d855c Quote Link to comment Share on other sites More sharing options...
Boris Posted August 22, 2008 Report Share Posted August 22, 2008 Do you by any chance have a SATA H/D in your notebook ? Quote Link to comment Share on other sites More sharing options...
bubble rida Posted August 22, 2008 Author Report Share Posted August 22, 2008 Not sure, i went to the manufacturers website and its not listed. How can i detemine what i have? Quote Link to comment Share on other sites More sharing options...
-pops- Posted August 22, 2008 Report Share Posted August 22, 2008 Check:http://support.microsoft.com/kb/330182 Quote Link to comment Share on other sites More sharing options...
bubble rida Posted August 22, 2008 Author Report Share Posted August 22, 2008 Thanks pops, i have visited that page several times. My computer has no operating system, a buddy told me to run gparted to remediate the problem. When i do, i am told i have no partitions. Quote Link to comment Share on other sites More sharing options...
Boris Posted August 22, 2008 Report Share Posted August 22, 2008 Is this the model you have ? http://panasonic.net/pavc/toughbook/busine.../#specificationYou say that "MY COMPUTER HAS NO OPERATING SYSTEM" - yet it seems to come with Vista Business pre-installed as standard ? - have you removed Vista ?When you say that you are "trying to install XP" onto your machine, exactly how have you gone about this ?How far have you got through the XP installation process ?This is an excellent guide as to how you should install XP.http://www.simplyguides.net/guides/xp_home...all_part1.shtml Quote Link to comment Share on other sites More sharing options...
bubble rida Posted August 22, 2008 Author Report Share Posted August 22, 2008 That link is to the correct model i have.In regards to how far i have gotten, not very far. I inserted my xp cd into my external dvd rom, everything seems to be loading, then im halted by the following:STOP: 0X0000007E (0XC0000005, 0XF854a0bf, 0XF8996208, 0XF8995f08)pci.sys - Address f854a0bf base at f8543000, Datestamp 3b7d855c Quote Link to comment Share on other sites More sharing options...
Boris Posted August 22, 2008 Report Share Posted August 22, 2008 How did you remove the Vista that was presumably pre-installed ? Quote Link to comment Share on other sites More sharing options...
Boris Posted August 22, 2008 Report Share Posted August 22, 2008 Can you just confirm that you are trying to install XP with an external USB connected DVD-drive ? Quote Link to comment Share on other sites More sharing options...
bubble rida Posted August 22, 2008 Author Report Share Posted August 22, 2008 Boris, i recieved the unit with no os, and yes, the dvd is connected thru the usb port. Quote Link to comment Share on other sites More sharing options...
Boris Posted August 22, 2008 Report Share Posted August 22, 2008 Does your BIOS support booting from an external USB DVD drive ? .... and if so, is it enabled ? Quote Link to comment Share on other sites More sharing options...
Boris Posted August 22, 2008 Report Share Posted August 22, 2008 Of the 12 screen shots showing the stages of installing XP posted in this guide :-http://www.simplyguides.net/guides/xp_home...all_part1.shtmlhow many does it go through before you get the error ? Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted August 22, 2008 Report Share Posted August 22, 2008 Perhaps your caps lock key is stuck and Windows refuses to boot. :lol: I edited all your posts to proper case. Please don't type in uppercase lettering I had this exact error once. You should choose to format (FULL not quick) when provided the option while installing Windows. Quote Link to comment Share on other sites More sharing options...
bubble rida Posted August 22, 2008 Author Report Share Posted August 22, 2008 SORRY ABOUT THE LONG WAIT, THE POWER HAS BEEN ON AND OFF. IM IN FLORIDA BY THE WAY, STILL GETTING HIT BY STORM. Quote Link to comment Share on other sites More sharing options...
bubble rida Posted August 22, 2008 Author Report Share Posted August 22, 2008 BORIS, THE THIRD SCREEN SHOT IS AS FAR AS I GET. YES, I CAN BOOT FROM THE USB DRIVE. Quote Link to comment Share on other sites More sharing options...
bubble rida Posted August 22, 2008 Author Report Share Posted August 22, 2008 scarecrow, i am not given the option to format. Quote Link to comment Share on other sites More sharing options...
Boris Posted August 23, 2008 Report Share Posted August 23, 2008 This could be a RAM problem ?Is this a brand new notebook ? - or has it been used before ? Quote Link to comment Share on other sites More sharing options...
bubble rida Posted August 23, 2008 Author Report Share Posted August 23, 2008 The notebook is used. Quote Link to comment Share on other sites More sharing options...
Boris Posted August 23, 2008 Report Share Posted August 23, 2008 Did you see it working properly before you acquired it ?Check that the RAM is properly seated in its slot. Here's a visual guide on how to do this :_http://www.orcalogic.co.uk/asp/InstallationGuide.htmWhat version of XP is your CD - Home or Pro ? What Service Pack does it include ? (should show on the label) Quote Link to comment Share on other sites More sharing options...
bubble rida Posted August 23, 2008 Author Report Share Posted August 23, 2008 Yes, the notebook was running, the seller deleted everything from the hard drive. I'm trying to install xp pro. Quote Link to comment Share on other sites More sharing options...
bubble rida Posted August 23, 2008 Author Report Share Posted August 23, 2008 Yes, the ram is seated in the slot. Quote Link to comment Share on other sites More sharing options...
Boris Posted August 23, 2008 Report Share Posted August 23, 2008 Does that CD include SP2 ? Quote Link to comment Share on other sites More sharing options...
Boris Posted August 23, 2008 Report Share Posted August 23, 2008 Yes, the notebook was running, the seller deleted everything from the hard drive. I'm trying to install xp pro.What O/S was it running when working - Vista ? Quote Link to comment Share on other sites More sharing options...
bubble rida Posted August 23, 2008 Author Report Share Posted August 23, 2008 I dont have sp2. It seemed to be running xp. Quote Link to comment Share on other sites More sharing options...
Boris Posted August 23, 2008 Report Share Posted August 23, 2008 I believe you need to have XP including SP2 for your install to work ?.You can make your own XP CD with Service Pack 2 slimstreamed into it ......... by using Autostreamer with your existing CD and a copy of Service Pack 2See instructions here :-http://www.neowin.net/forum/index.php?showtopic=223562 Quote Link to comment Share on other sites More sharing options...
