crossbone Posted November 20, 2008 Report Share Posted November 20, 2008 I accidentally deleted hundreds of my PSD files and like to retrieve all of them. I'm running XP Pro 64 and somehow, everytime I delete something, it doesn't go to the dustbin. back to my problem, what is the best free program I can use to recover my data? I have not formatted or done anything else to my hdd. please help. this is urgent and so important! Quote Link to comment Share on other sites More sharing options...
-pops- Posted November 20, 2008 Report Share Posted November 20, 2008 Try this http://www.recuva.com/ Quote Link to comment Share on other sites More sharing options...
crossbone Posted November 20, 2008 Author Report Share Posted November 20, 2008 Try this http://www.recuva.com/downloading now. thanks! Quote Link to comment Share on other sites More sharing options...
crossbone Posted November 20, 2008 Author Report Share Posted November 20, 2008 Try this http://www.recuva.com/downloading now. thanks!unfortunately no go. couldn't find the missing files even though I specified the folder :-( Quote Link to comment Share on other sites More sharing options...
Seshomaru Samma Posted November 21, 2008 Report Share Posted November 21, 2008 Try testdisc Read through the documentation in their websiteAlso try to not to write any data to your hard disc , in fact its best if you don't use it at all until you recover your data Quote Link to comment Share on other sites More sharing options...
Hb_Kai Posted November 21, 2008 Report Share Posted November 21, 2008 Try testdisc Read through the documentation in their websiteAlso try to not to write any data to your hard disc , in fact its best if you don't use it at all until you recover your dataWhy is that? Quote Link to comment Share on other sites More sharing options...
crossbone Posted November 21, 2008 Author Report Share Posted November 21, 2008 Try testdisc Read through the documentation in their websiteAlso try to not to write any data to your hard disc , in fact its best if you don't use it at all until you recover your dataWhy is that?problem solved! thanks for the help guys but I manage to recover everything with EASEUS Data recovery Wizard Pro. does the job clean and fast! Quote Link to comment Share on other sites More sharing options...
-pops- Posted November 21, 2008 Report Share Posted November 21, 2008 Why is that?Because Windows is likely to overwrite anything that is not correctly indexed. Quote Link to comment Share on other sites More sharing options...
