SpaRa16 Posted February 22, 2009 Report Share Posted February 22, 2009 Here's the thing I've recently re-installed windows after trying out linux (mad) and now most works but there are some stuff that annoy me for example when I try to install something (downloaded installer) when I click on it and press go it continues for a while but then says file is corrupt? What is this?Also I'm a diablo player and I've just re-installed it and when I try download patch it keeps kicking me (disconnecting) I can't download the patch :/ And now I'm also installing wow and I'm afraid same problems will occur anyone know the problem here? What have I forgot to install? Quote Link to comment Share on other sites More sharing options...
SpaRa16 Posted February 22, 2009 Author Report Share Posted February 22, 2009 Here's the thing I've recently re-installed windows after trying out linux (mad) and now most works but there are some stuff that annoy me for example when I try to install something (downloaded installer) when I click on it and press go it continues for a while but then says file is corrupt? What is this?Also I'm a diablo player and I've just re-installed it and when I try download patch it keeps kicking me (disconnecting) I can't download the patch :/ And now I'm also installing wow and I'm afraid same problems will occur anyone know the problem here? What have I forgot to install?Also I can't log into msn it keeps saying my contact list is unavalible.... Quote Link to comment Share on other sites More sharing options...
Boris Posted February 22, 2009 Report Share Posted February 22, 2009 It would be nice to know which version of Windows you re-installed ? Quote Link to comment Share on other sites More sharing options...
SpaRa16 Posted February 22, 2009 Author Report Share Posted February 22, 2009 It would be nice to know which version of Windows you re-installed ?Windows xp home edition.If this makes any sense to you. It's not always like this but way to many times.This is when I try install vlc.At avg virus protection. Quote Link to comment Share on other sites More sharing options...
SpaRa16 Posted February 22, 2009 Author Report Share Posted February 22, 2009 Seems like I cannot post more then 1 pic per thread :/ Anyway when I'm trying to install avg free protection it just say file is corrupted.Also I cannot log into my msn it just say contact list not avalible atm. Quote Link to comment Share on other sites More sharing options...
Boris Posted February 22, 2009 Report Share Posted February 22, 2009 You seem to have a Swedish Recycle Bin ? - is that correct ? Quote Link to comment Share on other sites More sharing options...
Boris Posted February 22, 2009 Report Share Posted February 22, 2009 It would be nice to know which version of Windows you re-installed ?Windows xp home edition.Have you done a full Windows Update to at least Service Pack 2 ? Quote Link to comment Share on other sites More sharing options...
SpaRa16 Posted February 22, 2009 Author Report Share Posted February 22, 2009 It would be nice to know which version of Windows you re-installed ?Windows xp home edition.Have you done a full Windows Update to at least Service Pack 2 ?sp3 even Quote Link to comment Share on other sites More sharing options...
Boris Posted February 22, 2009 Report Share Posted February 22, 2009 Have you tried using "sfc /scannow" from Run ? Quote Link to comment Share on other sites More sharing options...
SpaRa16 Posted February 22, 2009 Author Report Share Posted February 22, 2009 Have you tried using "sfc /scannow" from Run ?No I haven't but I tried now but how come it's asking for windows xp proffessional while I'm using home edition? I tried first with home edition disc but it said wrong disc :/ Luckily I got proffessional too. Quote Link to comment Share on other sites More sharing options...
SpaRa16 Posted February 22, 2009 Author Report Share Posted February 22, 2009 Have you tried using "sfc /scannow" from Run ?No I haven't but I tried now but how come it's asking for windows xp proffessional while I'm using home edition? I tried first with home edition disc but it said wrong disc :/ Luckily I got proffessional too.K it's done and still same :/ Is there anything else I can do? Quote Link to comment Share on other sites More sharing options...
Hb_Kai Posted February 22, 2009 Report Share Posted February 22, 2009 Is the version of Windows legal?And your MSN contact list could be a MSN server problem... Sometimes this happens when they mess up somehow. Quote Link to comment Share on other sites More sharing options...
SpaRa16 Posted February 22, 2009 Author Report Share Posted February 22, 2009 Is the version of Windows legal?And your MSN contact list could be a MSN server problem... Sometimes this happens when they mess up somehow.It's a legal version yes. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted February 23, 2009 Report Share Posted February 23, 2009 Is it the 'avg' downloads on your desktop you are trying to install? These do perfectly look like incomplete downloads - there is no valid icon on both downloads.Download it again, then try to reinstall. If possible, check the download size. Quote Link to comment Share on other sites More sharing options...
Dencandy Posted February 23, 2009 Report Share Posted February 23, 2009 What happens when you try to install using the standard Windows installer? The main problem would seem to be with the NSIS installer.Also, you can check the status of Windows & other programs using the Secunia Personal Software Inspector - it should tell you if any programs are missing patches, etc. It will also tell you what version of Windows & other software you have. You can get it HERE. A similar but more advanced inspector is available from BelArc. Quote Link to comment Share on other sites More sharing options...
