ɹəuəllıʍ ʇɐb Posted March 13, 2009 Report Share Posted March 13, 2009 System Tray Cleaner version 2 - from the makers of DriverMax.System Tray Cleaner is a simple tool which helps you quickly and easily remove unwanted items from your Windows system tray. The Windows system tray, also called the SysTray, is the lower-right corner of your screen, near the clock display, where Windows dumps some programs, most of the time programs which load during Windows startup.System Tray Cleaner will list all your system tray icon and identify which programs they belong to. Then, you can choose whether you wish to stop a certain program, remove it from startup (so it doesn't start automatically every time you turn on your computer) or simply uninstall it.Benefits:get rid of the clutter in your system tray quickly identify what each system tray icon does speed up your computer's start time easily remove programs from your startup don't start unnecessary programs speed up your computer by freeing your memory and CPU 100% FREE tool!To the best of our knowledge, System Tray Cleaner is the best tool for keeping your system tray clean, because it's the only tool which shows you what each icon means. This is often very hard to find out using other tools.System Tray Cleaner works on Windows Vista, Windows 7 and Windows XP.http://www.system-tray-cleaner.com/ Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted March 13, 2009 Author Report Share Posted March 13, 2009 I tried it, out of curiosity (I have no systray icons that I don't use).The initial scan took more than 30 minutes, then it showed all my systray icons, status (hidden or visible), all details behind the icon, and the option to end the task, uninstall, or remove from startup. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted March 13, 2009 Author Report Share Posted March 13, 2009 System Tray Cleaner remains active, watching the systray. When a new icon is entered into the systray, STC will come up with an analysis of the new icon. Quote Link to comment Share on other sites More sharing options...
andsome Posted March 13, 2009 Report Share Posted March 13, 2009 Surely this can be done after right clicking then customise. :D Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted March 13, 2009 Author Report Share Posted March 13, 2009 Right-click on what - the system tray?You can customize some individual systray tasks, but far from all.But anyway, there is no option in this System Tray Cleaner to just not show the icon, but let the task continue. You can only terminate the task, prevent it from starting at Windows startup, or uninstall it completely. Quote Link to comment Share on other sites More sharing options...
andsome Posted March 13, 2009 Report Share Posted March 13, 2009 This is my system tray at present. There is nothing to remove. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted March 13, 2009 Author Report Share Posted March 13, 2009 What happens if you click on the little Quote Link to comment Share on other sites More sharing options...
andsome Posted March 13, 2009 Report Share Posted March 13, 2009 What happens if you click on the little That is what I need to do to see them and activate them. I still can't see why they should need to be removed from behind there. I use Startup Advisor to decide what to run at start up. :D Quote Link to comment Share on other sites More sharing options...
CurlyWhirly Posted March 13, 2009 Report Share Posted March 13, 2009 What happens if you click on the little < ?That is what I need to do to see them and activate them. I still can't see why they should need to be removed from behind there. I use Startup Advisor to decide what to run at start up. :DI'm on vista but I'm sure XP has similar options? (I haven't used XP for a few months and have forgotten the layout)If you have the same options as me have you tried unticking the option 'Hide inactive icons' and customizing them? Quote Link to comment Share on other sites More sharing options...
andsome Posted March 13, 2009 Report Share Posted March 13, 2009 This is XP Home. Quote Link to comment Share on other sites More sharing options...
CurlyWhirly Posted March 18, 2009 Report Share Posted March 18, 2009 This is XP Home.Yes there's a customise option there I see.I used to customise XP when I used to use it much as I customise Vista now. Quote Link to comment Share on other sites More sharing options...
Dencandy Posted March 19, 2009 Report Share Posted March 19, 2009 Doesn't seem to add anything useful to the built-in Windows System Tray customise function. Or have I missed something? Quote Link to comment Share on other sites More sharing options...
leni Posted August 12, 2009 Report Share Posted August 12, 2009 Come on :) :) There are cleaning programs and Cleaning Programs. Better use Webroot Washer or Mil Shield, not this. They really work properly and clean all files, icons, and so on you want. Quote Link to comment Share on other sites More sharing options...
