xenon Posted March 23, 2009 Report Share Posted March 23, 2009 Hi peers hope that someone can help my with this problem,i can only install linux O.S. on my case and i am novice in linux so i dont like it when i try to install Windows Xp Pro after a few minutes of installation a blue screen appears with thisinformation i took notice: a problem has been detected and windows has been shutdown to prevent damage to your Pc,check for viruses on your Pc remove any newly installed harddiskdrive or harddiscontrollerscheck your harddisk if it properly configured and terminated.Run CHKDSK /F to check for harddrive corruption and then restart your computerTechnical information:***STOP: 0x0000007B (0xF78D2524,0xC0000034,0x00000000,0x00000000after first time i got this message i bought a new harddisk(western digital SATA160GB) so harddisk corruption can not be, and how can i check for viruses on my pc without an O.S. installed?How can i run CHKDSK /F ? (i know a lot of computing but i never heard of that)Or can it be i need to install a SATA driver first but how?where can i download it?p.s.: i dont have a floppydisk reader on my case (if that can be the solution? i dont know!) thank's to all who have some time to spend on the solution e-mail link removed for security. Please send any comments via the personal message link Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted March 23, 2009 Report Share Posted March 23, 2009 First you cannot run CHKDSK /F, as you need Windows installed to use that.What are the specifications and how old is the computer. Quote Link to comment Share on other sites More sharing options...
Seshomaru Samma Posted March 24, 2009 Report Share Posted March 24, 2009 1) You can check disc with a Linux cd , here is how (you can use a LiveCd so you don't actually need to install)2) If you need Sata drivers to install XP, you will have to slipstream them into your install media, you can use a programme like nlite 3. can you provide more information about the error - at what stage does it appear ? does it happen with the new HD you bought? what are your specs?4. another possibility is a faulty install media - can the disc work on other setup? Quote Link to comment Share on other sites More sharing options...
Boris Posted March 24, 2009 Report Share Posted March 24, 2009 I have merged this topic with an identical one (but with a different subject name) by the original poster. Quote Link to comment Share on other sites More sharing options...
xenon Posted March 24, 2009 Author Report Share Posted March 24, 2009 Alan ty i know it has to be windows installed to run CHKDSK /F,my Pc is seven months old it's an acer with quad core processer and 3072 ram,or whatyou mean with specifications?I have open suse 11.1 installed on it maybee that could be the problem, cause as i installed iti didnt have any problems, so how can i check the problem with Linux?It doesn't depend on the Windows i try to install i have many versions from original over cracked tocorporate edition! every time i try to install one of them i get this blue screen with the error message!The only thing i find strange is that i can install any Linux i want :open suse, ubuntu... no problems if it's the sata problem driver witch i can slip in with Nlite(i already have it installed on my pc,where can i get the SATA driver please? :( Great thanks for all your quick replys, i hope i answerd enough of your questuons posted so thatyou can help me i reallly need this case cause my Laptop doesn't accept nomore dvd's only cdrom'sso that i had to install magic disc to run .iso formatted windows installationsThanks for all your reply's peers Quote Link to comment Share on other sites More sharing options...
Boris Posted March 24, 2009 Report Share Posted March 24, 2009 if it's the sata problem driver witch i can slip in with Nlite(i already have it installed on my pc,where can i get the SATA driver please? :(Try the Western Digital support site ?http://support.wdc.com/product/download.as...1=6&lang=enSelect whichever model you have. Quote Link to comment Share on other sites More sharing options...
Seshomaru Samma Posted March 25, 2009 Report Share Posted March 25, 2009 xenon,as i explained in my previous post you can use your Linux partition to check the disc , the link i provided explains how to do it, the commands will be similar in your Suse OS.the reason you can't install XP most likely has to do with Sata drivers which the default XP media does not have (but most Linux distros do). slipstream it with nlite and you should be good to go (but the check the disc for errors and badblocks first) Quote Link to comment Share on other sites More sharing options...
xenon Posted March 26, 2009 Author Report Share Posted March 26, 2009 sorry Guys i gave you some wrong infromation: 1. i have ubuntu installed on th case 2. the new HDD is a seagate barracuda 160gb(the acer inbuild HDD was an WD) so i tryed to download a SATA driver for the seagate HDD no way can 't find one!and someone ask me when does the error message appears:just when the windows installation blue screen tryes to start windowsthats ALL I KNOW Quote Link to comment Share on other sites More sharing options...
Seshomaru Samma Posted March 26, 2009 Report Share Posted March 26, 2009 In my first post there is a link that explains how to CHKDSK in Ubuntuthe important question which you didnt answer is - does the installation actually begin?does windows recognise your disc?the 1st part of the installtion windows parts your disc and formats it - do you get to that part? if so it means that you do not need to slipstream SATA drivers, it means that you have another problem - probably a corrupt install media (your CD), a problem with your drive, or something else. can you post the output of lspci from your ubuntu partition? (applications>accessories>terminal) Quote Link to comment Share on other sites More sharing options...
